Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
  • 1.  Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
    Posted Feb 07, 2013 10:08 AM
    basically what the subject line says.
    If I have a network running 4 IAPs either 93s or 105s, since the RAP108-109s are instants as well, can they integrate into this network?
  • 2.  RE: Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
    Posted Feb 07, 2013 10:11 AM
    Yes -- you can mix IAP models within the same group.
    There is a caveat:
    IAP-92 /93 are limited to qty. 16 IAP and 256 concurrent connections per group.   Additionally, if you have an existing group of other IAP models (not -92 / -93) then introduce an IAP-92 / 93 to that group, the whole group will be held down to 16 IAP and 256 connections..
    This only applys to the IAP-9x.  All other models are unlimited in the number per group.
  • 3.  RE: Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
    Posted Feb 07, 2013 10:12 AM
    Great thanks.
    Actually I thoguht the restriction was removed with the latest firmware but is not recommended to go above 16...
  • 4.  RE: Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
    Posted Feb 07, 2013 10:14 AM
    The restriction only applys to the IAP-9x.
    All other IAP models are unlimited.
    But...............if you put an IAP-9x into a group of other IAP models they have to step down to th elowest common denominator  - the IAP-9x.
  • 5.  RE: Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
    Posted Feb 07, 2013 12:51 PM
    I mean the AP9x series 16 AP restriction was removed with the latest firmware but is not recommended to go above 16.
    The others have no restrictions
  • 6.  RE: Integrating Instant RAP108-109 into an exisiting IAP-93 or IAP-105 network possible?
    Posted Feb 07, 2013 05:56 PM
    The limit of 16 IAPs for the IAP-9x is nota suggestion it is the limit.  This has not changed.   If you add a 17th it will not join the group and it will not come up.   You need to p
    All other models are unlimited.
