Integration Aruba Amigopod (ClearPass Guest) with other vendors
  • 1.  Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jul 16, 2013 10:07 AM
    Hi, does anyone know, if ClearPass Guest is able to integration with Cisco and Ubiquiti.
  • 2.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jul 16, 2013 05:54 PM
    Cisco - yes. Ubiquity - it is good question - in CPPM/GM you have drop-down list with all predefined vendors in NAS/Web Login configuration.
    HTH
  • 3.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jul 17, 2013 03:37 AM
    As I understood, ClearPass Policy Manager can be integrated with:
    3com
    3GPP
    3GPP2
    Acc
    Acme
    ADSL-Forum
    Aerohive
    Airespace
    Alcatel
    Alcatel-Lucent-Service-Router
    Alteon
    Alvarion
    APC
    Aruba
    Ascend
    Avenda
    Azaire
    Bay-Networks
    BinTec
    CableLabs
    Cabletron
    ChilliSpot
    Cisco
    Cisco-BBSM
    Cisco-VPN3000
    Cisco-VPN5000
    Clavister
    Colubris
    Cosine
    Digium
    Epygi
    Ericsson
    ERX
    Extreme
    Fortinet
    Foundry
    Freeswitch
    Gandalf
    Gemtek
    H3C
    HP
    Huawei
    IEA-Software
    IETF
    infonet
    ipUnplugged
    Issanni
    ITK
    JRadius
    Juniper
    KarlNet
    Lancom
    Livingston
    Local-Web
    Lucent
    Manzara
    Merit
    Microsoft
    Mikrotik
    Navini
    Netscreen
    NetworkPhysics
    Nexans
    Nokia
    Nomadix
    Nortel
    NTUA
    Packeteer
    Patton
    Propel
    Prosoft
    Quiconnect
    Quintum
    Redback
    RedCreek
    Riverstone
    Roaring-Penguin
    Shasta
    Shiva
    Siemens
    Slipstream
    SofaWare
    SonicWall
    SpringTide
    Starent
    Symbol
    Telebit
    Trapeze
    Tropos
    T-Systems-Nova
    Unix
    USR
    UTStarcom
    ValemountNetworks
    Versanet
    Walabi
    Waverider
    Wichorus
    WISPr
    Xedia
    And ClearPass Guest can be integrated with:
    • Aerohive
    • Alcatel-Lucent
    • Bluesocket
    • ChilliSpot
    • Cisco
    • Colubris
    • HP
    • Consentry Networks
    • Dell
    • Enterasys
    • Extreme Networks
    • Extricom
    • Juniper
    • Meraki
  • 4.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jul 18, 2013 05:38 PM
    In the matter of fact you can integrate CPPM with any kind of 802.1x device, because you can add RADIUS dictionary. But you have to bear in mind that Guest is completely different thing - there is such kind of proper http parameter passing integration. So the list you just got from the GUI is quite accurate.
    Many regards,
    Marek
  • 5.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jul 19, 2013 01:58 AM
    ok .Thank you.
  • 6.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jul 20, 2013 05:07 PM
    If you think that my answers were helpful, please kudo/mark as solved.
    Regards
  • 7.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Nov 14, 2013 02:55 AM
    You can add Ruckus to that list for Clearpass Guest.
  • 8.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Nov 14, 2013 03:10 AM
    Thanks mike. I will add it to our docs
  • 9.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Mar 09, 2014 05:39 PM
    Do all functions of Clearpass Guest integrate with Extricom?
    I know Radius authetication does work with predefined accounts, but does it work properly with email or sms Registration, and does ist work with MAC Authentication for returning Guests?
    Thanks, Rene
  • 10.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Mar 10, 2014 12:29 AM
    Hopefully someone in the community can speak up, in the past 5 years Ive been in the NAC field I have never came across them.
    Looking at their docs it shows it has an interal captive portal but I couldnt find anything where it supports external, so you may not be able to use the self reg. You could only do CP auth from their software. You should be able to do MAC cacheing but I dont have any conformation for you.
  • 11.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Jun 07, 2014 04:42 PM
    Anyone integrated with meraki mdm? (Free version) Is it even possible?
  • 12.  RE: Integration Aruba Amigopod (ClearPass Guest) with other vendors
    Posted Sep 09, 2014 08:46 AM
    Hi; did you get a complete answer as to the extent of integration with Extricom? I would be keen to know too. thanks.
