Integration Clearpass to McAfee
  • 1.  Integration Clearpass to McAfee
    Posted Sep 12, 2022 04:50 AM
    Dear All,
    we would like to login to Next gen IPS McAfee via radius Clearpass, but i cannot find radius dictionary McAfee in Clearpass,
    is there any documentation for integration Clearpass with McAfee for login purpose ?
    kindly need your help
    thanks
    BR,
    Hudaya
  • 2.  RE: Integration Clearpass to McAfee
    Posted Sep 12, 2022 09:10 AM
    Many products just work with the standard (IETF) dictionary. Did you find in the documentation which attributes should be returned by ClearPass?
    I did a quick search, but could not find that documentation which may be behind a portal login. Also, I know that McAfee (and others) bought parts of their portfolio, so the dictionary may be even something different like the original vendor name. As far as I know there is no 'McAfee' as it is many different products and each may have a different guide. Please work with McAfee to find which RADIUS atributes ClearPass should return (Aruba Support probably doesn't have that information), then if you can't make it work yourself, work with your Aruba partner or Aruba support for further assistance.
  • 3.  RE: Integration Clearpass to McAfee
    Posted Sep 13, 2022 02:10 AM
    Dear @Herman Robers,
    i've seen profiling privilege from their mcafee server,
    it's seems mcafee server same like fortigate, they profiling privilege with roles,
    ​i will update it when we successfully integrate it
    thanks,
    BR,
    Hudaya
