Integration with 3com switch for wired authentication
  • 1.  Integration with 3com switch for wired authentication
    Posted Jun 15, 2016 12:02 AM
    Hi, customer is using 3com switch, and request to integrate with Clearpass for wired authentication.
    From the Clearpass, we can see the authentication showing ACCEPT, and the output tab showing the RADIUS parameters (VLAN etc).
    But on the end device, it will keep showing to prompt the credentials. I believe in the Clearpass the settings is straight forward.
    Is there anything I need to check on the 3com switch? Is wired using CoA?
    Crone
  • 2.  RE: Integration with 3com switch for wired authentication
    Posted Jul 13, 2017 03:52 AM
    Hi Crone
    Was you able to get 3COM switch work?
    As I have same case.
