Inteherited vs local configurations on MC's
  • 1.  Inteherited vs local configurations on MC's
    Posted Oct 18, 2019 06:24 PM
    I have 2 MC's that have a mixed configuration.
    Most of the configuraiton is inherited from the /MD/xx node-hierarchy.
    Some is configured locally.
    Is there an easy way to strategically restore the inheritance for a few things for example "wlan ssid-profile" or "wlan virtual-ap"?
  • 2.  RE: Inteherited vs local configurations on MC's
    Posted Oct 18, 2019 07:16 PM
    Type "show configuration node-hierarchy"
    type "CD <name of your node>"
    If you type "show configuration committed" at that level, it will tell you everything you have configured only at that node.
  • 3.  RE: Inteherited vs local configurations on MC's
    Posted Oct 19, 2019 01:52 AM
    Thank you... that helped remove some of those changes on the individual controller.
    Should NTP settings be set in the /md/controller and inherited down at the actual MC?  or actually set on the MC?
  • 4.  RE: Inteherited vs local configurations on MC's
    Posted Oct 19, 2019 04:57 AM
    If all controllers need to have the same ntp server, it can be created as high up as /md.
  • 5.  RE: Inteherited vs local configurations on MC's
    Posted Oct 22, 2019 08:03 PM
    As Cjoseph stated, settings such as NTP can be set as high up as /md, however it is generally recommended that you do not make changes at the /md level. Create an organizational group node below /md and make your global settings at that level. Such as /md/<company name>/<location>/ and then in the location group node you would then have your device nodes. Your global settings would be made at /md/<company name>. With a Mobility Master (MM) you can have a maximum hierarchy depth of 4 group node levels, eg. /md/level1/level2/level3/level4/devicenode.
    I hope this helps,
