Intelligent Power Monitoring, config or default?
  • 1.  Intelligent Power Monitoring, config or default?
    MVP
    Posted Apr 10, 2017 10:42 AM
    I'm deploying a network of AP330's and cam across the ipm-enable command.
    Should I be tinkering with this?  Enable it but don't configure further? What is the default config actualy?
    I don't realy care for USB and eth1, but do care about all the rest (very highly loaded APs). Should I set usb and eth1 to priority 1 and not configure anythign else?  Or should I configure the rest to a higher priority?
    Some clarification would be appreciated
  • 2.  RE: Intelligent Power Monitoring, config or default?
    Posted Apr 10, 2017 10:55 AM
    You should not tinker with it.  You should just provide high-powered POE to all of your APs so you don't have to worry about them.
  • 3.  RE: Intelligent Power Monitoring, config or default?
    MVP
    Posted Apr 19, 2017 06:22 AM
    And when without 802.3at, I'm guessing tinkering won't do anything since it automatically disables well... everything but the minimal radio functionality (1x1) right?
    Power Status
    Item                        Value
    Power Supply                : POE-AF
    LLDP Power                  : 0.0W
    Current Operational State   : USB and eth1 disabled, 1x1 chain for both Radios
    And a related question. Is there a simple command to get an overview of that power status for all APs?  Or am I stuck with using  'show ap debug system-status ap-name' AP per AP?
