Inter-user Routing/Bridging
  • 1.  Inter-user Routing/Bridging
    Posted May 23, 2014 12:52 PM
    Does anyone know if there are any plans to make Inter-user Routing/Bridging in Instant a per SSID item instead of a system wide option?
    Customer wants to enable this, but only in the guest SSID.
    #ALE
  • 2.  RE: Inter-user Routing/Bridging
    Posted Jun 02, 2014 08:35 AM
    I would suggest to try to do it like this :
     - Under System -> enable the "Deny local routing" (it will block communications between clients on different WLAN's)
     - Under the role of the Guest SSID you add a rule with deny traffic to the Guest subnet (don't forget to exclude the Gateway and DNS in case you have them local defined)
    That should provide some level of security :)
  • 3.  RE: Inter-user Routing/Bridging
    Posted Jun 02, 2014 08:39 AM
    I have already added this type of request as an idea. Thus promote :
    https://arubanetworkskb.secure.force.com/prm/ideas/viewIdea.apexp?id=08740000000LEfL
  • 4.  RE: Inter-user Routing/Bridging
    Posted Jun 11, 2014 12:47 PM
    it seems that they have added this feature in 4.1 OS:
    Disabling of Bridging and Routing Traffic between Clients Connected to an SSID
    You can now disable bridging and routing traffic between two clients connected to an SSID. When inter-user bridging
    and local routing is denied, the clients can connect to the Internet but cannot communicate with each other, and the
    bridging and routing traffic between the clients is sent to the upstream device to make the forwarding decision.
    To deny inter-user bridging and local routing for the WLAN SSID clients, run the following commands at the CLI:
    (Instant AP)(config)# wlan ssid-profile <ssid-profile>
    (Instant AP) (SSID Profile <ssid-profile>)# deny-inter-user-bridging
    (Instant AP) (SSID Profile <ssid-profile>)# deny-local-routing
    (Instant AP) (SSID Profile <ssid-profile>)# end
    (Instant AP)# commit apply
  • 5.  RE: Inter-user Routing/Bridging
    Posted Aug 13, 2014 12:41 AM
    Aruba should make this available in the GUI!
  • 6.  RE: Inter-user Routing/Bridging
    Posted Aug 13, 2014 01:08 AM
  • 7.  RE: Inter-user Routing/Bridging
    Posted Aug 13, 2014 01:10 AM
    Sorry, I meant per VLAN.
