Comware
Inter Vlan Routing in HPE 5140EI Switch (JL826A)
  • 1.  Inter Vlan Routing in HPE 5140EI Switch (JL826A)
    Posted May 11, 2023 10:53 AM
    I have a HPE 5140EI Switch. I want to run my Layer3 function in same switch. Vlan creation, Interface creation is done. Please help me to enable intervlan routing in HPE 51040EI Switch. Find Configuration of switch below.
    [SNIMS-CORE]display current-configuration
     version 7.1.070, Release 6327
     sysname SNIMS-CORE
     clock timezone Chennai add 05:30:00
     clock protocol none
     telnet server enable
     irf mac-address persistent timer
     irf auto-update enable
     undo irf link-delay
     irf member 1 priority 1
     irf member 2 priority 1
     dhcp enable
     lldp global enable
     transceiver phony-alarm-disable
     password-recovery enable
    vlan 1
    vlan 10
     name DATA-FIRST
    vlan 20
     name DATA COMMON
    vlan 30
     name DATA NURSING
    vlan 40
     name DATA-COLLEGE
    vlan 50
     name VOICE
    vlan 60
     name WiFi-GUEST
    vlan 70
     name WiFi-SNIMS
    vlan 100
     name SERVER
     description Server vlan
    vlan 110
     name CCTV
    vlan 200
     name FWLAN
     description Connection to FGT
    vlan 210
     name MGMT
     description Management Vlan
    irf-port 1/1
     port group interface Ten-GigabitEthernet1/0/28 mode normal
    irf-port 2/2
     port group interface Ten-GigabitEthernet2/0/28 mode normal
     stp global enable
    dhcp server ip-pool CCTV
     gateway-list 172.16.0.1
     network 172.16.0.0 mask 255.255.240.0
     dns-list 192.168.1.16
    dhcp server ip-pool DATA-COMMON
     gateway-list 10.10.20.1
     network 10.10.20.0 mask 255.255.254.0
    dhcp server ip-pool DATA-College
     gateway-list 10.10.40.1
     network 10.10.40.0 mask 255.255.254.0
    dhcp server ip-pool DATA-FIRST
     gateway-list 10.10.10.1
     network 10.10.10.0 mask 255.255.254.0
    dhcp server ip-pool DATA-Nursing
     gateway-list 10.10.30.1
     network 10.10.30.0 mask 255.255.254.0
    dhcp server ip-pool VOICE
     gateway-list 10.10.50.1
     network 10.10.50.0 mask 255.255.254.0
    dhcp server ip-pool WiFi-GUEST
     gateway-list 10.10.60.1
     network 10.10.60.0 mask 255.255.255.0
     dns-list 8.8.8.8
    dhcp server ip-pool WiFi-SNIMS
     gateway-list 10.10.70.1
     network 10.10.70.0 mask 255.255.255.0
    interface NULL0
    interface Vlan-interface10
     ip address 10.10.10.1 255.255.254.0
    interface Vlan-interface20
     ip address 10.10.20.1 255.255.254.0
    interface Vlan-interface30
     ip address 10.10.30.1 255.255.254.0
    interface Vlan-interface40
     ip address 10.10.40.1 255.255.254.0
    interface Vlan-interface50
     ip address 10.10.50.1 255.255.254.0
    interface Vlan-interface60
     ip address 10.10.60.1 255.255.255.0
    interface Vlan-interface70
     ip address 10.10.70.1 255.255.255.0
    interface Vlan-interface100
     ip address 192.168.1.1 255.255.254.0
    interface Vlan-interface110
     ip address 172.16.0.1 255.255.240.0
    interface Vlan-interface200
     ip address 10.10.200.1 255.255.255.0
    interface Vlan-interface210
     ip address 10.10.210.1 255.255.255.0
    interface GigabitEthernet1/0/1
     port link-type trunk
     port trunk permit vlan all
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
     combo enable auto
    interface GigabitEthernet1/0/18
     combo enable auto
    interface GigabitEthernet1/0/19
     combo enable auto
    interface GigabitEthernet1/0/20
     combo enable auto
    interface GigabitEthernet1/0/21
     combo enable auto
    interface GigabitEthernet1/0/22
     combo enable auto
    interface GigabitEthernet1/0/23
     combo enable auto
    interface GigabitEthernet1/0/24
     port access vlan 110
     combo enable auto
    interface GigabitEthernet2/0/1
    interface GigabitEthernet2/0/2
    interface GigabitEthernet2/0/3
    interface GigabitEthernet2/0/4
    interface GigabitEthernet2/0/5
    interface GigabitEthernet2/0/6
    interface GigabitEthernet2/0/7
    interface GigabitEthernet2/0/8
    interface GigabitEthernet2/0/9
    interface GigabitEthernet2/0/10
    interface GigabitEthernet2/0/11
    interface GigabitEthernet2/0/12
    interface GigabitEthernet2/0/13
    interface GigabitEthernet2/0/14
    interface GigabitEthernet2/0/15
    interface GigabitEthernet2/0/16
    interface GigabitEthernet2/0/17
     port access vlan 10
     combo enable auto
    interface GigabitEthernet2/0/18
     combo enable auto
    interface GigabitEthernet2/0/19
     combo enable auto
    interface GigabitEthernet2/0/20
     combo enable auto
    interface GigabitEthernet2/0/21
     combo enable auto
    interface GigabitEthernet2/0/22
     combo enable auto
    interface GigabitEthernet2/0/23
     combo enable auto
    interface GigabitEthernet2/0/24
     combo enable auto
    interface M-GigabitEthernet0/0/0
    interface Ten-GigabitEthernet1/0/25
    interface Ten-GigabitEthernet1/0/26
    interface Ten-GigabitEthernet1/0/27
    interface Ten-GigabitEthernet2/0/25
    interface Ten-GigabitEthernet2/0/26
    interface Ten-GigabitEthernet2/0/27
     scheduler logfile size 16
    line class aux
     user-role network-admin
    line class vty
     authentication-mode scheme
     user-role network-operator
    line aux 0 1
    line vty 0 63
     ssh server enable
     ssh user manager service-type stelnet authentication-type password
     ip route fast-switchover enable
    radius scheme system
     user-name-format without-domain
    domain system
     aaa session-limit ssh 2
     domain default enable system
    role name level-0
     description Predefined level-0 role
    role name level-1
     description Predefined level-1 role
    role name level-2
     description Predefined level-2 role
    role name level-3
     description Predefined level-3 role
    role name level-4
     description Predefined level-4 role
    role name level-5
     description Predefined level-5 role
    role name level-6
     description Predefined level-6 role
    role name level-7
     description Predefined level-7 role
    role name level-8
     description Predefined level-8 role
    role name level-9
     description Predefined level-9 role
    role name level-10
     description Predefined level-10 role
    role name level-11
     description Predefined level-11 role
    role name level-12
     description Predefined level-12 role
    role name level-13
     description Predefined level-13 role
    role name level-14
     description Predefined level-14 role
    user-group system
    local-user manager class manage
     password hash $h$6$PMCb1fHgHdB8Xkyb$JV5hJbgYc4t7mWxKzwQjBRiEGLVQysoAjPB+KMQHpo4+9w/lKx+MjghT2Z4VTPCX7FJWAPoN0smoB6G/URwCLQ==
     service-type http https ssh terminal
     authorization-attribute user-role level-15
     authorization-attribute user-role network-operator
     ip http enable
    return
    [SNIMS-CORE]
  • 2.  RE: Inter Vlan Routing in HPE 5140EI Switch (JL826A)
    Posted May 11, 2023 04:30 PM
    It is enabled by default.
    Ivan Bondar
