Comware
inter-Vlan routing msr1003-8
  • 1.  inter-Vlan routing msr1003-8
    Posted Sep 11, 2018 09:16 AM
    Hello everybody,
    I first work with msr1003.
    I have problem with inter-Vlan routing.
    my test network:
    laptop1 192.168.0.2/24 DG192.168.0.1/24
    laptop2 192.168.1.2/24 DG192.168.1.1/24
    3 com 2920 port1 vlan11 access/ port2 vlan22 access/ port10 vlan 11 22 trunk
    msr1003:
    port0/3 link-mode route
    port0/3.11 vlan-type dot1q vid 11 ip192.168.0.1/24
    port0/3.22 vlan-type dot1q vid 22 ip192.168.1.1/24
    msr1003 ping all
    laptops ping all
    laptops not ping each othe
    Why?
    Where do I need to look?
    In the documentation I can not find the necessary section
  • 2.  RE: inter-Vlan routing msr1003-8
    Posted Sep 12, 2018 01:16 AM
    People,
    Completed the settings for the documentation  Configuring VLAN termination (https://support.hpe.com/hpsc/doc/public/display?sp4ts.oid=4178998&docLocale=en_US&docId=emr_na-c05327929)
    Does not work.
    What else should I read?
  • 3.  RE: inter-Vlan routing msr1003-8
    Posted Sep 12, 2018 11:47 PM
    There are specialists of the company HP?
    Why I buy an expensive device I can not get normal technical support?
    For inter-Vlan need conf ACL, PBR?
  • 4.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 03:40 AM
    Kindly look into the attached diagram and it seems to be similar like your network. Kindly Confirm.
    Can you  share the current configuration of both of the devices (Router & Switch).
    Thank You!
    I am an HPE Employee
  • 5.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 04:09 AM
    I'm very glad that someone answered.
    The diagram is correct.
    conf msr1003:
    #Jan  1 01:09:20:314 2013 HPE SHELL/4/LOGIN:
     Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1: login from Console
    %Jan  1 01:09:20:314 2013 HPE SHELL/5/SHELL_LOGIN: Console logged in from aux0.
    <HPE>sys
    System View: return to User View with Ctrl+Z.
    [HPE]dis current-configuration
     version 5.20.106, Release 2516P13
     sysname HPE
     firewall enable
     domain default enable system
     ip ttl-expires enable
     ip unreachables enable
     ip icmp-extensions compliant
     dar p2p signature-file flash:/p2p_default.mtd
     port-security enable
     password-recovery enable
    acl number 2000
     rule 1 permit source 192.168.0.0 0.0.0.255
    acl number 2001
     rule 1 permit source 192.168.1.0 0.0.0.255
    vlan 1
    domain system
     access-limit disable
     state active
     idle-cut disable
     self-service-url disable
    user-group system
     group-attribute allow-guest
    local-user admin
     password cipher $c$3$KORVvCVvx1zipr13BVmoYnokDZFAwXby
     authorization-attribute level 3
     service-type telnet
     service-type web
    cwmp
     undo cwmp enable
    interface Aux0
     async mode flow
     link-protocol ppp
    interface Cellular0/0
     async mode protocol
     link-protocol ppp
    interface NULL0
    interface Vlan-interface1
    interface GigabitEthernet0/0
     port link-mode route
     ip address 192.168.10.1 255.255.255.0
    interface GigabitEthernet0/1
    interface GigabitEthernet0/3
    interface GigabitEthernet0/3.11
     firewall packet-filter 2001 outbound
     ip address 192.168.0.1 255.255.255.0
    interface GigabitEthernet0/3.22
     firewall packet-filter 2000 outbound
     ip address 192.168.1.1 255.255.255.0
    interface GigabitEthernet0/2
     port link-mode bridge
    interface GigabitEthernet0/4
    interface GigabitEthernet0/5
    interface GigabitEthernet0/6
    interface GigabitEthernet0/7
    interface GigabitEthernet0/8
    interface GigabitEthernet0/9
     load xml-configuration
     load tr069-configuration
    user-interface tty 12
    user-interface aux 0
    user-interface vty 0 4
     authentication-mode scheme
    return
    conf 3com 2920:
     version 5.20 Release 1519P03
     sysname 3Com Baseline Switch
    vlan 1
    vlan 11
    vlan 22
    domain system
     state active
     idle-cut disable
    user-group system
    local-user admin
     service-type ssh telnet terminal
     service-type web
     stp mode rstp
     stp enable
    interface NULL0
    interface GigabitEthernet1/0/1
     port access vlan 11
     stp edged-port enable
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
     port access vlan 11
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
     port access vlan 22
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
     port access vlan 22
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
     port link-type hybrid
     port hybrid vlan 11 22 tagged
     port hybrid vlan 1 untagged
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
    interface GigabitEthernet1/0/18
    interface GigabitEthernet1/0/19
    interface GigabitEthernet1/0/20
     snmp-agent
     snmp-agent local-engineid 8000002B0320FDF16DEC14
     snmp-agent sys-info version v3
    user-interface vty 0 15
    return
    Thank you!
  • 6.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 05:33 AM
    Thank You for your reply!
    Can you mention which port of 2920 is connecting to MSR 1003?
    i believe MSR 1003 interface 0/3 is coneecting to 2920 switch? Kindly correct me if I am wrong.
    Thank You!
  • 7.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 05:57 AM
    2920:
    port1/0/10
    msr1003:
    port0/3
    msr1003:
    [HPE]dis ip routing-table
    Routing Tables: Public
            Destinations : 6        Routes : 6
    Destination/Mask    Proto  Pre  Cost         NextHop         Interface
    127.0.0.0/8         Direct 0    0            127.0.0.1       InLoop0
    127.0.0.1/32        Direct 0    0            127.0.0.1       InLoop0
    192.168.0.0/24      Direct 0    0            192.168.0.1     GE0/3.11
    192.168.0.1/32      Direct 0    0            127.0.0.1       InLoop0
    192.168.1.0/24      Direct 0    0            192.168.1.1     GE0/3.22
    192.168.1.1/32      Direct 0    0            127.0.0.1       InLoop0
    [HPE]
  • 8.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 07:06 AM
    I have replicated the same into simulator and it is working fine for me.
    PC1 on different VLAN is able to Ping PC2 on different VLAN and similarly for PC2 to PC1.
    For testing purpose tried in both ways:
    1. Similary like you configuration where MSR port is in route mode and 2920 port is trunk.
    2. Create vlan interface 11 & 22 on MSR router and port connecting to switch make as trunk port and pass the vlan.
    In my setup I have used one msr router, one comware switch and 2 PC's.
    Can you try after removing firewall commands on both of the switches?
    If still issue remains then kindly log a case with support.
    Thank You!
  • 9.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 07:48 AM
    2. Create vlan interface 11 & 22 on MSR router...
    I do not quite understand what it means.
    interface Vlan-interface11
    interface Vlan-interface22
    or
    ip address 192.168.0.1/24
    ip address 192.168.1.1/24
    I removed firewall, but no result.
    Can I see your configuration msr?
  • 10.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 08:02 AM
    For me it worked from both type. Below is the configuration of both types:
    1. MSR while using Router on Stick:
    combo enable copper
    interface GigabitEthernet0/0.11
    interface GigabitEthernet0/0.22
    Ping Result:
    <H3C>ping 192.168.0.1
    Ping 192.168.0.1 (192.168.0.1): 56 data bytes, press CTRL_C to break
    56 bytes from 192.168.0.1: icmp_seq=0 ttl=255 time=2.000 ms
    56 bytes from 192.168.0.1: icmp_seq=1 ttl=255 time=1.000 ms
    56 bytes from 192.168.0.1: icmp_seq=2 ttl=255 time=1.000 ms
    56 bytes from 192.168.0.1: icmp_seq=3 ttl=255 time=2.000 ms
    56 bytes from 192.168.0.1: icmp_seq=4 ttl=255 time=1.000 ms
    --- Ping statistics for 192.168.0.1 ---
    5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss
    round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms
    <H3C>%Sep 13 17:18:51:539 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.0.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms.
    <H3C>ping 192.168.1.1
    Ping 192.168.1.1 (192.168.1.1): 56 data bytes, press CTRL_C to break
    56 bytes from 192.168.1.1: icmp_seq=0 ttl=255 time=2.000 ms
    56 bytes from 192.168.1.1: icmp_seq=1 ttl=255 time=1.000 ms
    56 bytes from 192.168.1.1: icmp_seq=2 ttl=255 time=2.000 ms
    56 bytes from 192.168.1.1: icmp_seq=3 ttl=255 time=1.000 ms
    --- Ping statistics for 192.168.1.1 ---
    4 packet(s) transmitted, 4 packet(s) received, 0.0% packet loss
    round-trip min/avg/max/std-dev = 1.000/1.500/2.000/0.500 ms
    <H3C>%Sep 13 17:18:58:540 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.1.1: 4 packet(s) transmitted, 4 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.500/2.000/0.500 ms.
    ping 192.168.1.2
    Ping 192.168.1.2 (192.168.1.2): 56 data bytes, press CTRL_C to break
    56 bytes from 192.168.1.2: icmp_seq=0 ttl=254 time=3.000 ms
    56 bytes from 192.168.1.2: icmp_seq=1 ttl=254 time=3.000 ms
    56 bytes from 192.168.1.2: icmp_seq=2 ttl=254 time=2.000 ms
    56 bytes from 192.168.1.2: icmp_seq=3 ttl=254 time=3.000 ms
    --- Ping statistics for 192.168.1.2 ---
    round-trip min/avg/max/std-dev = 2.000/2.750/3.000/0.433 ms
    <H3C>%Sep 13 17:19:01:983 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.1.2: 4 packet(s) transmitted, 4 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 2.000/2.750/3.000/0.433 ms.
    2. MSR while using bridge mode and passing vlan 11 & 22
    port link-type trunk
    port trunk permit vlan all
    combo enable copper
    Ping Result:
    56 bytes from 192.168.1.1: icmp_seq=0 ttl=255 time=6.000 ms
    56 bytes from 192.168.1.1: icmp_seq=1 ttl=255 time=2.000 ms
    56 bytes from 192.168.1.1: icmp_seq=2 ttl=255 time=1.000 ms
    round-trip min/avg/max/std-dev = 1.000/2.500/6.000/2.062 ms
    <H3C>%Sep 13 17:26:26:937 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.1.1: 4 packet(s) transmitted, 4 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/2.500/6.000/2.062 ms.
    ping 192.168.1.2
    56 bytes from 192.168.1.2: icmp_seq=0 ttl=255 time=0.000 ms
    56 bytes from 192.168.1.2: icmp_seq=1 ttl=255 time=0.000 ms
    56 bytes from 192.168.1.2: icmp_seq=2 ttl=255 time=0.000 ms
    3 packet(s) transmitted, 3 packet(s) received, 0.0% packet loss
    round-trip min/avg/max/std-dev = 0.000/0.000/0.000/0.000 ms
    <H3C>%Sep 13 17:26:28:971 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.1.2: 3 packet(s) transmitted, 3 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.000/0.000/0.000 ms.
    ping 192.168.0.1
    2 packet(s) transmitted, 2 packet(s) received, 0.0% packet loss
    <H3C>%Sep 13 17:26:33:212 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.0.1: 2 packet(s) transmitted, 2 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.500/2.000/0.500 ms.
    ping 192.168.0.2
    Ping 192.168.0.2 (192.168.0.2): 56 data bytes, press CTRL_C to break
    56 bytes from 192.168.0.2: icmp_seq=0 ttl=254 time=6.000 ms
    56 bytes from 192.168.0.2: icmp_seq=1 ttl=254 time=8.000 ms
    56 bytes from 192.168.0.2: icmp_seq=2 ttl=254 time=3.000 ms
    --- Ping statistics for 192.168.0.2 ---
    round-trip min/avg/max/std-dev = 3.000/5.667/8.000/2.055 ms
    <H3C>%Sep 13 17:26:35:358 2018 H3C PING/6/PING_STATISTICS: Ping statistics for 192.168.0.2: 3 packet(s) transmitted, 3 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 3.000/5.667/8.000/2.055 ms.
    Have you removed firewall and acl from interfaces as well?
    If the issue remains then kindly log a case with support.
    Thank You!
  • 11.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 08:38 AM
    thanks for working with me
    I rewrote the configuration and it worked
    I do not know what was the reason, but inter-vlan worked
  • 12.  RE: inter-Vlan routing msr1003-8
    Posted Sep 13, 2018 08:56 AM
    It has been an absolute pleasure working with you and, thank you for continuing to choose HPE.
    Thank You!
