@maraujo wrote:
We are using AP 105 with our controller. We are noticing some times a drop in the wireless, like the AP's reboot on their own and our Door Access system is receiving an overload of information. The security company said they are using 319.5 Mhz for their door access and security system. The system is registering an overload of data and is sometimes becoming on cooperative. Could there be a correlation?
Any thoughts would be appreciated.
/Marc
We need much more information. What version of ArubaOS are you using? If they use 319.5mhz they should not interfere. Interference can be troublesome, so you should definitely open a TAC case if you have not already, in parallel to your post.
