Internal Captive Portal does not load on apple captive network
This thread has been viewed 37 times
  • 1.  Internal Captive Portal does not load on apple captive network
    Posted Feb 23, 2024 12:38 AM
    Issue with internal captive portal loading when connecting to an ssid with captive portal enforced. We are using a publicly signed cert for our IAP from Sectigo. What am I doing wrong here?
  • 2.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 23, 2024 03:31 AM
    Is the captive portal working for other devices?
    Are you getting an IP address when you connect to the captive portal SSID in question? - You should be getting an IP address even if your page does not load.
    In a new tab, try putting in a random IP address as 2.2.2.2 and see if it redirects you to the expected page.
    What does your configuration look like for this SSID?
    /AJ
  • 3.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 25, 2024 09:06 PM
    MacOS and IOS devices have this issue.
    The devices are getting IPs from DHCP.
    The SSID has a pre authentication role that enforces the internal captive portal.
  • 4.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 26, 2024 12:53 AM
    If the Apple device uses Safari or some other browser, does the page work properly?
    Carson Hulcher, ACEX#110
  • 5.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 26, 2024 11:32 PM
    Yes, the page loads when opened by another browser. However we are trying to implement a T&C page with the internal captive portal, hence it is not practical if the user has to open the page on their browser even after they have been granted internet access.
  • 6.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 26, 2024 11:40 PM
    The point was to validate if the redirect to the captive portal and subsequent login action worked outside of the Apple CNA browser.
    Working outside of CNA = problem with CNA.
    Not working outside of CNA = configuration incorrect.
    Stay connected to the guest WLAN while dismissing the CNA browser, in a normal browser open a page like neverssl.com to test redirect.
  • 7.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 27, 2024 06:55 AM
    Your response makes sense. However we need to play by apple's rules when it comes to integrating with their devices.
  • 8.  RE: Internal Captive Portal does not load on apple captive network
    Posted Feb 27, 2024 10:26 AM
    Go ahead and open a case with TAC.
  • 9.  RE: Internal Captive Portal does not load on apple captive network
    Posted Mar 06, 2024 11:32 AM
    Any luck with TAC? I have the same issue.
  • 10.  RE: Internal Captive Portal does not load on apple captive network
    Posted Mar 06, 2024 07:20 PM
    Still gathering logs from controller, device, etc.
    I suspect this was caused by an incorrect DNS set by the device, since the controller's domain name record can only be found on the local DNS. I found that not all connected devices face this CNA issue, it was also reported "intermittent" by the device owner. I have yet to come across another device in the network with the same issue.
  • 11.  RE: Internal Captive Portal does not load on apple captive network
    Posted Mar 07, 2024 01:56 AM
    "incorrect DNS" for what?
