The built-in captive portal for the controller does not support time limitations or features like MAC Caching.
With ClearPass you can create a click-to-accept portal, and add time/bandwidth limits and MAC Caching. I don't have a step by step description for that on ClearPass, but if you know ClearPass it shouldn't be too hard.
Original Message:
Sent: Feb 01, 2024 01:52 AM
Subject: Internal Captive Portal with no Auth or Registration Required
Our company would like to setup a quick access Guest SSID which I have already setup. However, I couldn't find an option where to set a restriction so I can limit the duration of a guest user access to the network. I tried looking tru different forums but couldn't find any. I would like to know if this is possible if so, I would greatly appreciate any tips or recommendations. Thanks!
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/fdb61d58859f471eb0d0fbf3a932ca45.png)
On the other hand, I was also trying in my lab to setup the same no auth or registration required but using Aruba Clearpass captive portal. Has anyone already tried to? As I couldn't get this work. So i was wondering if this is possible?
Thank you so much in advance.
