Internal dabatase question
  • 1.  Internal dabatase question
    Posted Apr 15, 2014 07:31 PM
    The internal dabase which as far i know it support up to 4000 entries
    The limit applies to all the controllers?
    This limit is even on the 7200 series?
    Cheers
    Carlos
  • 2.  RE: Internal dabatase question
  • 3.  RE: Internal dabatase question
    Posted Apr 15, 2014 09:32 PM
    Helllo victor
    Like i said on that tread
    The mac address limit does not match to what i see
    The client got 2800 entiries on a 3200 with memory upgrade
    It should be able just to go up to 2048 but its goes beyond that...
    he is using 6.2.1.5 Firmware
  • 4.  RE: Internal dabatase question
    Posted Apr 15, 2014 09:54 PM
    The only thing I could think of is that 2048 is the recommended number for best performance but the AOS won't restrict you from going over , similar to the internal DHCP before 6.3 that the recommended number was 512 but you could go over but now it gives you a warning message when you go over.
  • 5.  RE: Internal dabatase question
    Posted Apr 15, 2014 11:59 PM
    Well that could be...
    Anyone from aruba can confirm this? if so i need to warm some clients :)
    Carlos
