@solo_11 wrote:
I´m using captive portal and I have a few differents guest admin accounts and I would like to know if I can limit the number of clients that a guest admin can create and also if I can see the logs of guest connections??
BR.
You cannot limit the number of users created with the controller's built-in captive portal. You can certainly do this with amigopod http://www.arubanetworks.com/products/management-security-software-2/amigopod-visitor-management-2
To see logs of guest users connection, you would have to turn on debugging. You also would probably want to direct the output of the controller to a syslog server to keep historical logs:
config t
logging level debugging security process authmgr
subcat all
You would then type "show log security 50" to see the authentication activity of those users and/or log to an external syslog server.
