Internal db loose entry
  • 1.  Internal db loose entry
    Posted Jun 29, 2016 04:50 AM
    I have a issue with the internal db.
    We have some have on some ssid´s with mac auth + 802.1 X.
    The internal db is loose again and again one entry. I have write it again in the db a few times. But after a random time the entry isn´t in the db.
    Yes I apply the edit of the db and save configuration too.
    Anyone have this problem bevor or have any ideas?
    Cheers
  • 2.  RE: Internal db loose entry
    Posted Jun 29, 2016 05:02 AM
    How many total entries do you have?
  • 3.  RE: Internal db loose entry
    Posted Jun 29, 2016 05:06 AM
    We will have 334 entries in the internal db. Its a Aruba3200 controller.
    But any time it’s the same entire I think. Least no other user is reporting, that he can´t login to the network.
  • 4.  RE: Internal db loose entry
    Posted Jun 29, 2016 05:16 AM
    Hi!
    After it happens, if you issue: "show audit-trail xxx | include <the mac>" Do you see it getting deleted?
    I´ve seen this at a customer who enabled management from Airwave and then added entries from the controller. Airwave would just keep removing them if it´s set up that way :)
    Try and add another dummy entry to the db to see if that one also dissapears at the same time.
    Cheers,
  • 5.  RE: Internal db loose entry
    Posted Jun 29, 2016 05:29 AM
    Hi Christoffer,
    first at the moment we don´t have airwave.
    When i look at the controller i can see only that i have add the mac address to the internal db.
    I will have a look at the audit-trail...
    Thanks for the first responses.
  • 6.  RE: Internal db loose entry
    Posted Jul 14, 2016 04:38 AM
    Sadly he is removed from the Database again. In the audit-trail I only can see that I have added the user tow times. The last time and now after he is disappear in the database again.
    #show audit-trail | include 7c:d1:c3:7f:57:3a
    Jun 29 07:57:33  webui[1697]: USER:jreppin@<ipaddress> COMMAND:<local-userdb add username "<mac-address>" password ******  role "bk_device_all" email "MacBook@tlichtner.w2" > -- command executed successfully
    Jul 14 10:33:00  webui[1697]: USER:jreppin@<ipaddress> COMMAND:<local-userdb add username "<mac-address>" password ******  role "bk_device_all" email "MacBook@tlichtner.w2" > -- command executed successfully
    Someone any ideas?
