internal domain pc's
  • 1.  internal domain pc's
    Posted Nov 13, 2014 12:02 PM
    How can I get my pc's in my domain to authenticate
    I have it all set up for user auth but when I switch it to computer only
    I get the error on my radius server that the authentication failed due to a user credentials mismatch
  • 2.  RE: internal domain pc's
    Posted Nov 13, 2014 12:03 PM
    Do you have the Machine Group: Domain Computers in your NPS/IAS policy?
  • 3.  RE: internal domain pc's
    Posted Nov 13, 2014 12:07 PM
    yes I do I tried it with the windows group and with a machine group
    and it still does not connect same error
  • 4.  RE: internal domain pc's
    Posted Nov 13, 2014 01:32 PM
    Can you include a complete output of the NPS event log entry for this as well as a successful authentication for users?   Can you confirm that when using machine authentication you are hitting the same NPS Network Policy that your users are (when they are successful)?
  • 5.  RE: internal domain pc's
    Posted Nov 13, 2014 02:35 PM
    I am just trying to get the computer to authenticate without the user
    if I add a user to that nps policy then I am prompted for credentials if I put them in which are in the group that the nps points too I get on as I should
    so how can I get the pc to just connect before a user logs on
  • 6.  RE: internal domain pc's
    Posted Dec 10, 2014 07:06 AM
    If you are still having this issue, please share the NPS logs from both a successful authentication and a failed authentication.
    Are you using PEAP-MSCHAPv2 or EAP-TLS?    If you are using EAP-TLS, the computer will need a certificate as well as the user.
