I am very new to Aruba and Airwave but I would like to create a guest wireless SSID that uses the Aruba internal splash page with Radius authentication. I have the splash page set up and successfully connected Airwave to our Radius server and I can authenticate over it for our WPA2 SSID.
For the guest SSID what I had envisioned was to use the internal splash page but pass the credentials on to the radius server. I have attached the screenshot of the settings I currently have. So what happens is when I connect to the SSID it gives me the splash page asking for a login, I then type in a username and password that is valid in Radius and it comes back and tells me its invalid. I know the creds are valid because I use them daily on airwave for another SSID and it works just fine, its just for some reason when I combine the internal splash page and radius it does not work. Anything I am doing wrong here?
Daniel
