Internal System error - should I be concerned?
  • 1.  Internal System error - should I be concerned?
    Posted Dec 23, 2015 05:57 AM
    Keep gettitng this error everywhere:
    Dec 23 13:08:19 2015 XXXXXXXXX sapd[1731]: <326268> <ERRS> |AP XXXXXXX@XXXXXXX sapd| An internal system error has occurred at file channel.c function ch_check line 1382 error default_ch_cnt 0 .
    I have removed the IPs and AP names with X's.
    Anyone seen this?  It all seems functional, but cant help thinking not optimal?
  • 2.  RE: Internal System error - should I be concerned?
    Posted Dec 23, 2015 06:52 AM
    You need to open a TAC case.  How servere it is depends on the message and the version of ArubaOS.
  • 3.  RE: Internal System error - should I be concerned?
    Posted Dec 23, 2015 07:50 AM
    Opening case!  Will update with outcome later :)
  • 4.  RE: Internal System error - should I be concerned?
    Posted Dec 23, 2015 07:51 AM
    Anyone looking at this thread I am using:
    ArubaOS (MODEL: Aruba650), Version 6.4.2.5
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-02-24 at 22:02:57 PST (build 48774) by p4build
  • 5.  RE: Internal System error - should I be concerned?
    Posted Feb 08, 2016 08:11 AM
    Relates to channel use in particular regulatory domains.  We have a bunch of WIFI networks all controller from a single master pair that applies appropriate regulatory domains depending on the country etc.
    apparently additional channels need to be assigned per TAC advice
    ...although I can help thinking that these channels are disabled to comply with the regulatory domain?
  • 6.  RE: Internal System error - should I be concerned?
    Posted Feb 08, 2016 08:13 AM
    ask TAC and get back to us...
  • 7.  RE: Internal System error - should I be concerned?
    Posted Feb 08, 2016 08:14 AM
    :) OK!
