Internet and network access only works from the current Master IAP, but why?
  • 1.  Internet and network access only works from the current Master IAP, but why?
    Posted Apr 21, 2016 07:30 AM
    We trying to set an instant, VC based wireless network, but have some troubles. SSID's configured with the correct subnets and DHCP pool. (Local DHCP scopes with type local, I think we need for this, VC should be the DHCP server and the gateway too)
    So we use NAT, and the situation is that, the internet and network access only works from the current Master IAP, and only from the master. I tried to set manually my ip address when I connected to another IAP, but I cannot ping my gateway.
    If I connect to that IAP, who is the currently master, everything works perfect.
    What could be the problem?
  • 2.  RE: Internet and network access only works from the current Master IAP, but why?
    Posted Apr 21, 2016 07:46 AM
    Solved: I thinked the DHCP requests gone toward VC through tunnel, but not, need to create the vlans between the IAPs.
  • 3.  RE: Internet and network access only works from the current Master IAP, but why?
    Posted Apr 21, 2016 08:07 AM
    If you create an SSID that has Client IP Assignment of "Network Assigned", the DHCP server MUST be external to the IAP network and that VLAN MUST be trunked to all of the IAPs.
    If you create an SSID that has Client IP Assignment of "Virtual Controller Assigned", DHCP is done by the VC through an "internal" VLAN.   All of the user traffic for that SSID is tunneled to the VC and Natted from it.  DHCP MUST be provided by the VC in that situation, and the VLAN is NOT trunked to any IAPs.
  • 4.  RE: Internet and network access only works from the current Master IAP, but why?
    Posted Apr 29, 2016 07:24 AM
    We configured the second option, so the VC is the DHCP server for the internal (wifi) users. But until we didn't create the VLANs on the switch, thats assigned for the SSIDs (vlan 2 and 3), the connection didn't work, on the APs, only works from the current Master IAP.
    We tried to set IP settings manually, but didn't work too, wasn't connection to the default gateway.
    Now works, but need to be create the vlan 2 and 3 on the switch, and set tagged to the switchport where AP was connected (native vlan: 1, and the external DHCP is in vlan 1, who is set IP addresses to the APs after boot up)
    Our config:
    version 6.4.4.0-4.2.3
    syslocation "xxxxxxxxxxxxxxxxxxxxxxxx"
    virtual-controller-country HU
    virtual-controller-key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    name xxxxxx
    virtual-controller-ip 172.16.0.100
    terminal-access
    rf-band all
    allowed-ap xx:xx:xx:xx:xx:xx
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 18
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode default-access
     client-aware
     scanning
    ip dhcp pool
     lease-time 59
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    mgmt-user admin xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    wlan access-rule AAAAA
     index 0
     rule 172.22.0.0 255.255.254.0 match any any any deny
     rule any any match any any any permit
    wlan access-rule default_wired_port_profile
     index 1
    wlan access-rule wired-instant
     index 2
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule BBBBB
     index 3
     rule 172.22.0.1 255.255.255.255 match tcp 4343 4343 deny
     rule 172.22.20.0 255.255.254.0 match any any any deny
    wlan ssid-profile AAAAA
     enable
     index 0
     type employee
     essid AAAAA
     wpa-passphrase uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
     opmode wpa2-psk-aes
     max-authentication-failures 0
     vlan 2
     rf-band all
     captive-portal disable
     dtim-period 1
     broadcast-filter arp
     deny-inter-user-bridging
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
     dot11r
     dot11k
     dot11v
    wlan ssid-profile BBBBB
     enable
     index 1
     type employee
     essid BBBBB
     wpa-passphrase zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
     opmode wpa2-psk-aes
     vlan 3
     rf-band all
     dtim-period 1
     enforce-dhcp
     dot11r
     dot11k
     dot11v
    auth-survivability cache-time-out 24
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
     https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
    ip dhcp bbbb_scope
     server-type Local
     server-vlan 3
     subnet 172.22.0.0
     subnet-mask 255.255.254.0
     lease-time 3540
     dns-server 8.8.8.8
    ip dhcp aaaaa_scope
     server-type Local
     server-vlan 2
     subnet 172.22.20.0
     lease-time 3540
     dns-server 8.8.8.8
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemptionw
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
