I've tried this a number of times, but keep running into this issue. For particular ssid, the internet is blocked except for a particular website.
I've allowed through the ssl cert provider for this website for CRL & certificate checking. The problem is that IE is always really slow to start up and takes up to 30-40 seconds.
If I put an allowall at the bottom, it starts up in 4-5 seconds. I've looked at the firewall and captures and can't seem to figure out what is causing the hold up.
I disabled 'automatically check proxy settings' in IE and this had minimal effect.
Has anyone else come across this and have any suggestions?
