internet link speed on wireless to slow
  • 1.  internet link speed on wireless to slow
    Posted Sep 18, 2013 11:55 AM
    Hi All,
    We are facing issues with sppedteston wireless with aruba ap´s 105 ans 7200 controller.
    Link to the internet is 50mbps and we are getting only 3-4 mbps on wireless.
    What could be the issue?
    Aruba is connected to the " internet HP Switch" that connects to Fortinet firewall.
    I could send you the scheme of the network
    Config attached..
    Regards
  • 2.  RE: internet link speed on wireless to slow
    Posted Sep 18, 2013 12:02 PM
    We need more information:
    - How many access points?
    - What version of ArubaOS
    - What encryption are your clients using?
    - How many SSIDs
    - Did you do an internal speedtest
    - What client did you do the speedtest with?
  • 3.  RE: internet link speed on wireless to slow
    Posted Sep 18, 2013 05:52 PM
    - How many access points? 65 installed
    - What version of ArubaOS  6.2
    - What encryption are your clients using? one wpa2 and the other open with captive portal
    - How many SSIDs . 2 ssid s
    - Did you do an internal speedtest - yes internal gives high values on wired
    - What client did you do the speedtest with? speedtest.net
  • 4.  RE: internet link speed on wireless to slow
    Posted Sep 18, 2013 05:53 PM
    Are you dropping broadcasts in your Virtual Aps on those two SSIDS?
  • 5.  RE: internet link speed on wireless to slow
    Posted Sep 18, 2013 05:58 PM
    I see that on the community but seems not doing nothing put on the vap droping  broadcast
  • 6.  RE: internet link speed on wireless to slow
    Posted Sep 18, 2013 06:02 PM
    You need to put "drop broadcast and multicast" on BOTH of your virtual Aps.
    Are you testing with an 802.11n client?
    How many users are connected to that access point when you are testing?
    Are your access points connected to gigabit ethernet ports?
  • 7.  RE: internet link speed on wireless to slow
    Posted Sep 18, 2013 06:09 PM
    for today the wireless ssid´s  are restricted only to a few test users.
    i will check tomorrow if i Put on both drop broadcast and multicast...
    yes i am testing with an n Client and Ap´s are connected gigabit
  • 8.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 04:30 AM
    Option OK on both SSid´s
  • 9.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 10:31 AM
    link over the wired 50mbps
    link on wireless 4 to 6 mbps
    This is strange.
    Aruba is connected on gi 0/0/1 to a procurve switch ( force 100 full).   Then this switch is connected to Fortinet
  • 10.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 10:38 AM
    Do you see any errors on the Aruba or procurve interfaces?  type show interface on the Aruba side to make sure it did not negotiate poorly or have any errors.
  • 11.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 10:57 AM
    Gi on Aruba seems ok...
  • 12.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 11:05 AM
    Is it on auto or is it fixed? You have the other side fixed, right?
    I would open a support case, because your problem could exist in many places, and it would take awhile to guess all of those places here.
  • 13.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 12:14 PM
    its already open.
    fixed on both sides
  • 14.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 12:21 PM
    Do you have a bandwidth contract on your user role?
  • 15.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 12:34 PM
    all saying not enforced..
  • 16.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 12:50 PM
    Now looking at that image, there are 77809 input errors, 77809 CRC errors on that interface.
    That is your probem.
  • 17.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 02:05 PM
    Damm.. I was looking to output errors ;(( and collisions..
    I will check with auto negociation if it works.
    Updated you tomorrow
    Port trusted??
    Regards
  • 18.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 02:11 PM
    I would check/ the cable between the controller and the switch...
  • 19.  RE: internet link speed on wireless to slow
    Posted Sep 19, 2013 02:33 PM
    Also that yes;)
  • 20.  RE: internet link speed on wireless to slow
    Posted Sep 24, 2013 06:27 AM
    done.
    Port on the procurve switch was  set to auto...
    Aruba was forced at 100 mbps full.
    Problem solved! auto on both ends!
    Thanks cjoseph
    Regards
