Interpreting Log Data
  • 1.  Interpreting Log Data
    Posted Dec 15, 2015 04:20 PM
    Hi all,
    When i ran an ARM history log, i seem to have a lot of the following..
    2015-12-15 16:49:58  13           13-          21         21         NO40INT
    2015-12-15 15:55:34  13           13-          21         21         NO40INT
    2015-12-15 14:25:39  13           13-          21         21         NO40INT
    2015-12-15 13:36:13  13           13-          21         21         NO40INT
    2015-12-15 13:10:58  13           13-          21         21         NO40INT
    2015-12-15 11:57:44  13           13-          21         21         NO40INT
    2015-12-15 10:45:44  13           13-          21         21         NO40INT
    2015-12-15 10:02:06  13           13-          21         21         NO40INT
    2015-12-15 09:12:50  13           13-          21         21         NO40INT
    2015-12-15 06:23:02  13           13-          21         21         NO40INT
    2015-12-15 04:39:42  13           13-          21         21         NO40INT
    2015-12-15 03:37:12  13           13-          21         21         NO40INT
    2015-12-15 02:44:22  13           13-          21         21         NO40INT
    2015-12-15 01:40:32  13           13-          21         21         NO40INT
    2015-12-15 01:05:23  13           13-          21         21         NO40INT
    2015-12-14 23:49:21  13           13-          21         21         NO40INT
    2015-12-14 20:31:41  13           13-          21         21         NO40INT
    Question really is what does NO40INT actually mean?
    I appreciate it's labelled as 'intol' but i have no idea what that means either!
  • 2.  RE: Interpreting Log Data
    Posted Dec 15, 2015 04:58 PM
    If you look at the legend below the output of the command, you will see:
    NO40INT: 40MHz intol cleared on 2.4G
    You also have channel 13-  You should not be running 40mhz channels on the 2.4ghz band...
  • 3.  RE: Interpreting Log Data
    Posted Dec 15, 2015 04:59 PM
    That refers to HT 40MHz Intolerance.
    Rajaguru Vincent
  • 4.  RE: Interpreting Log Data
    Posted Dec 15, 2015 05:27 PM
    Thanks guys,
    So what does it mean by 'intolerant'?
    I guess thats interefernce?
  • 5.  RE: Interpreting Log Data
    Posted Dec 15, 2015 07:05 PM
    Set Wide channels to 5ghz only and see if it goes away.
  • 6.  RE: Interpreting Log Data
    Posted Dec 17, 2015 01:59 AM
    Ok well that seems to have sorted it i think.
    The reason i say i think, is that the log is showing im on channel 13-, but the AP is shwing im on channel 1?
    Time of Change       Old Channel  New Channel  Old Power  New Power  Reason
    The BSS table also shows Ch1.
  • 7.  RE: Interpreting Log Data
    Posted Dec 17, 2015 05:09 AM
    Is 12-15 the last time it changed channel?
  • 8.  RE: Interpreting Log Data
    Posted Dec 17, 2015 11:45 AM
    This is the complete log..
    2015-12-14 13:02:42  9            13-          21         21         INV
    2015-12-14 13:02:42  9            9            21         21         40INT
    2015-12-14 12:42:31  9+           9+           Max        21         P-
    As you can see it shows 16.49 on December 15th.
    I've just got in now and re-run the log, (as above) and it still shows the same, and doesn't register here as being on Ch1, which it still is.
    And, as you suggested recently, i have set wide channels to 5GHZ only.
    Also...
    Just spotted this...
    Minimum Transmit Power            :30
    Maximum Transmit Power            :127
    Band Steering Mode       :disable
    Client Aware             :enable
     This is the Arm configuration log.
    I have ARM set to ... min 15 and max to max, for both bands.
  • 9.  RE: Interpreting Log Data
    Posted Dec 17, 2015 02:46 PM
    I have now checked the 2.4 network with my laptop and it is indeed curently on Ch1.
  • 10.  RE: Interpreting Log Data
    Posted Dec 18, 2015 01:53 PM
    Anyone??
  • 11.  RE: Interpreting Log Data
    Posted Dec 18, 2015 01:58 PM
    As a practical matter, changing the wide channels to only 5ghz is a manual, not an adaptive radio management change, so it probably won't update the history until ARM changes the channel from 1 or to another power.
