Wired Intelligent Edge
Intervlan routing
  • 1.  Intervlan routing
    Posted Sep 06, 2017 05:52 PM
    I'm having a issue with getting acces from vlan 11 to vlan 14
    the DHCP server is on Vlan 11 and it is suppose to give IP addresses to devices on Vlan 12-14 but i can't get it to work.
    Here it the config atm.
    ip route 0.0.0.0 0.0.0.0 172.18.231.1
    ip route 172.16.1.14 255.255.255.255 172.18.231.1
    ip route 172.16.1.27 255.255.255.255 172.18.231.1
    ip route 192.168.1.0 255.255.255.0 172.18.231.1
    ip routing
    interface 47
    name "SRV-IMM"
    exit
    interface 48
    name "DRAYTEK-LAN"
    exit
    snmp-server community "public" unrestricted
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1-44,47-52
    untagged 45-46
    no ip address
    exit
    vlan 11
    name "SHIP NET"
    untagged 1-34,36-44,47-52
    tagged 45-46
    ip address 172.18.231.254 255.255.255.0
    ip helper-address 172.18.231.20
    exit
    vlan 12
    name "CREW NET"
    tagged 45-46,49-50
    ip address 172.18.232.254 255.255.255.0
    exit
    vlan 13
    name "CUSTOMER NET"
    tagged 45-46,49-50
    ip address 172.18.233.254 255.255.255.0
    exit
    vlan 14
    name "MAINT NET"
    untagged 35
    tagged 45-46,49-50
    ip address 172.18.234.254 255.255.255.0
    exit
    vlan 500
    name "WAN NET"
    no ip address
    exit
    primary-vlan 11
    management-vlan 11
    spanning-tree
    spanning-tree mode rapid-pvst
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
    password manager
    Best regards Andreas
  • 2.  RE: Intervlan routing
    Posted Sep 07, 2017 04:22 AM
    Is it just dhcp-relay that is not working, and have you tested the IP routing by configuring a client with a static IP and default gateway to verify that IP routing is working? Do clients get an IP address?
    One thing that I found is that on vlan 11:
    vlan 11
      name "SHIP NET"
      tagged 45-46
    You have an ip helper-address in the same subnet. This should not be done, as the DHCP server should respond directly in that subnet, not via an IP-helper.
    If it is indeed just a DHCP issue (and removing the helper from vlan 11 does not resolve your issue), you can check the statistics from the dhcp-relay:
