Hi All,
I have a setup running with DMZ and local controller, guest are authenticating in DMZ controller and all the trafiic is going through GRE tunnel.
Now I need to configure another Guest SSID with external captive portal for TESTING.
The external captive portal server also sits behind DMZ.
I know I have to configure some intial role in DMZ and then assign the external captive portal profile to that intial role.
But how do I tell to DMZ controller that for this testing SSID use this initial role ?
Here I am getting confused, normally in my running setup unauthenticated guest pick up guest-logon role as a initial role.
Thanks in advanced.
