Intigrating Aruba WLC with Cisco ISE(NAC)
  • 1.  Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 22, 2024 10:34 AM
    Dear ALL,
    We require support for integrating Aruba  WLC (hosted on Azure cloud and os version is  8.10.7) with Cisco ISE 3.x for .1X wireless authentication, MAB authentication, and guest sponsored access. Please note that there is no ClearPass in place.
  • 2.  RE: Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 22, 2024 11:35 AM
    Below is a guide by Adam Hollifiled I have pointed other customers to in the past. It is a great starting point for all of your questions and a specific walkthrough on the Captive Portal configuration.
    How to: Cisco ISE CP
    .1x WLAN Configuration can be very straight forward using standard RADIUS IEFT Values.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 26, 2024 01:13 AM
    thank you for your'e valuable reply ,
    we're following same document but problem in one step for that kindly look at attachement
  • 4.  RE: Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 22, 2024 12:12 PM
    You're running a virtual mobility controller in Azure with AOS 8.10.0.7?
    Carson Hulcher, ACEX#110
  • 5.  RE: Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 26, 2024 01:19 AM
    yes chulcher yes we're running AOS 8.10.0.7 on azure cloud and following one document but problem in one step for that kindly look at attachement
  • 6.  RE: Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 26, 2024 09:15 AM
    If you are running a virtual gateway (VGW) on Azure Cloud then the software is either AOS 8.7.0.0-2.x.x.x (no longer supported) or AOS 10, not AOS 8.10.0.7, and that virtual appliance would only support the VPN concentrator (VPNC) role.  You could be running AOS 8.10.0.7 on Central managed Instant APs.
  • 7.  RE: Intigrating Aruba WLC with Cisco ISE(NAC)
    Posted Mar 27, 2024 05:36 AM
    Dear chulcher,
    thank you for your'e valuable reply. i got information from my team like running WLC on cloud and stuckked  while integrating  aruba centeral with Cisco Ise in that can you please provide  document to integrate it
