Intune Auth Source
This thread has been viewed 32 times
  • 1.  Intune Auth Source
    Posted Jan 20, 2023 06:05 AM
    I've followed this guide to try and get the extra Intune attributes for a device
    Intune extension 6 is installed and can sync with Intune and import devices into the endpoint configuration
    I'm using the filter query of %{Certificate:Subject-CN}
    However, all that will happen is I get
    HTTP attribute query returned error=404
    Edit: I think I see the issue. All the devices have a machine cert from Active Directory CA. So the Certificate:Subject-CN matches x335 however that doesn't match the Intune Device Id which is used in the lookup.
    Is there anyway to read two machine certs or force the authorization intune query to matchCertificate:Subject-CN which returns x335 and then get the Intune Device ID from that and run the query?
  • 2.  RE: Intune Auth Source
    Posted Jan 26, 2023 06:10 AM
    Could your issue be that you have multiple certificates installed on the client, one from AD and one from Intune, and the client is selecting the wrong certificate during the authentication (the AD one instead of the Intune one)?
    If that is the case, in your supplicant configuration you can change simple certificate selection to one issued by a specific CA:
    And, make sure that the certificate issued through Intune has the Intune DeviceID as the Subject-CN, which is not the default.
  • 3.  RE: Intune Auth Source
    Posted Jan 27, 2023 04:59 AM
    Hi Herman,
    Thank you! I guess I'm tripping myself up a tad by looking at authenticating on premise AD devices but also some of the Azure only devices. I've got a much better understanding of what is happening now.
