Intune Extension - Integration with two different Azure customer environments
  • 1.  Intune Extension - Integration with two different Azure customer environments
    Posted May 09, 2022 07:51 AM
    Hello Airheads,
    Anyone knows or has successfully deployed Intune Extension v5 on the same CPPM Guest cluster for two different Azure environments.
    Is that possible or are there any limitation(s) i.e Only 1 integration per cluster ?
    Many thanks,
    DSP
  • 2.  RE: Intune Extension - Integration with two different Azure customer environments
    Posted May 20, 2022 09:53 AM
    Yes, you can install the extension twice and put different configuration in each of them to connect to multiple Intune instances.
