Comware
"Invalid file name." when trying to load patch on 5130
  • 1.  "Invalid file name." when trying to load patch on 5130
    Posted Jul 06, 2022 02:05 PM
    We have a stack of 5130-24G-4SFP+ EI (JG932A)
    This week there was a security bulletin that we should update the device to the latest version. (R3507P02 or higher)
    Normally we just use complete images now its just a patch.
    So now I'm trying to add this patch: 5130_EI_7.10.R3507P02
    Its already running R3507
    The instructions are
    <>install activate patch flash:/5130_EI_7.10.R3507P02 all
    When I do that I just get a
    "flash:/5130_EI_7.10.R3507P02: Invalid file name."
    this is strange because the file name is 100% correct, also I tried to copy it to both sloths etc but no succes.
    On the console I see the message
    PKG/5/PKG_INSTALL_ACTIVATE_FAILED: -IPAddr=10.100.3.96-User=*******: Failed to executed the install activate command
    Anybody an idea how to fix this?
  • 2.  RE: "Invalid file name." when trying to load patch on 5130
    Posted Jul 07, 2022 03:07 AM
    Hello hw-iggy,
    You can dowknoad the zip file. Then extract the .ipe file from it and update as you are proceeding as the other images you have been updating.
    You can check the release notes.
    Hope this helps!
    -Alex-
  • 3.  RE: "Invalid file name." when trying to load patch on 5130
    Posted Jul 07, 2022 04:34 AM
    Ah thank you Alex,
    This was the trick, extract the file first!
    There is no info about this in the release notes and its also not vissible that this was a zip file.
