invalid image format
This thread has been viewed 24 times
  • 1.  invalid image format
    Posted Jan 17, 2014 10:32 AM
    I am trying to add 2 new Aruba AP-105 to our existing Aruba network with no success. I connect a console cable to the AP-105, and found this error. Look like the image is corrupted? Hit to stop autoboot: 0 Checking image @ 0xbf100000 Invalid image format version: 0xffffffff Checking image @ 0xbf800000 Invalid image format version: 0xffffffff I was using the “setenv serverip” command to point it to one of the working aruba to get the image, but got this error. Using eth0 device TFTP from server 192.168.10.2; our IP address is 192.168.10.246 Filename 'mips32.ari'. Load address: 0x2000000 Loading: T T T T T T T T T T Retry count exceeded; starting again anyone know the fix? manually reloading the OS? thanks.
  • 2.  RE: invalid image format
    Posted Jan 17, 2014 10:47 AM
    Are these IAP-105s or AP-105s? They cannot be used interchangeably.
    Sent from my iPhone
  • 3.  RE: invalid image format
    Posted Jan 17, 2014 11:09 AM
    Hi Yan, thank you for your reply.
    All devices are showing this. I don't have physical access to the device at this point, but i will check on Monday. thanks.
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
  • 4.  RE: invalid image format
    Posted Jan 20, 2014 02:23 PM
    Try a factory reset by holding the pin and then plugging in power to it.
    Plug it into the network (same subnet) assuming it provides DHCP (or else configure a static)
    It will then discover the VC automatically, no need to setenv serverip.
  • 5.  RE: invalid image format
    Posted Jan 20, 2014 02:47 PM
    I used the "upgrade os" command to upgrade the OS, it loaded, but showing a lot of error saying "turn off mobility"
    I also noticed on the existing AP105, there is a small sticker showing IAP-105, the new APs only show AP-105, what's the difference between the two? thanks.
    After the upgrade, the new AP boot,
    <<<<<       Welcome to the Access Point     >>>>>
    Launching IAP CLI...
    process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
    asap_send_elected_master: sent successfully
    wait for stm to initialize over
    turn off mobility
    (19:17:06) !!! Init ---> Slave
    turn off mobility
    User: (19:17:07) !!! Init ---> Slave
    turn off mobility
    (19:17:08) !!! Init ---> Slave
    turn off mobility
    (19:17:09) !!! Init ---> Slave
    turn off mobility
    (19:17:10) !!! Init ---> Slave
    turn off mobility
  • 6.  RE: invalid image format
    Posted Jan 20, 2014 02:54 PM
    Are you trying to use a NON Instant AP in an Instant cluster? Campus or RAP Based AP-105 in a IAP-105 cluster??
    That will not work.
  • 7.  RE: invalid image format
    Posted Jan 20, 2014 03:14 PM
    Hi Pmonardo
    I don't know the difference between IAP and AP, I am new to Aruba.
    I only know we have a few AP-105, didn't know there is IAP105 until now. so the AP-105 can be use as standalone AP only?
    thanks.
  • 8.  RE: invalid image format
    Posted Jan 20, 2014 03:17 PM
    AP-105 is a controller-based AP and requires an external Aruba controller appliance and licensing.
    The IAP-105, aka Instant, is controller-less.  All the control / management function is built into the IAP.
    You cannot mix AP-105 and IAP-105 in the same cluster as IAPs can only manage other IAPs.
  • 9.  RE: invalid image format
    Posted Jan 21, 2014 09:05 AM
    So what you wanna do is contact your Aruba sales person and discuss the option of purchasing an Aruba controller for you AP-105s along with licensing.
    Here is a link to the controller based APs from Aruba's website
    http://www.arubanetworks.com/products/access-points/
    Here is a link to the Instant (Cloud) based APs from Aruba's website
    http://cloud.arubanetworks.com/products
    You can easily identiyf whether an AP is instant or not but looking at the bottom of you will see the following for example
    IAP-105. Look carefully.
