invalid set request
  • 1.  invalid set request
    Posted Apr 17, 2024 02:58 PM
    Hi
    I am trying to configure a guest WLAN using clearpass captive portal, when I hit finish I get an error saying "invalid set request" but it still creates the network. What does that error mean?
    Thank you!
  • 2.  RE: invalid set request
    Posted Apr 17, 2024 11:47 PM
    you need to provide a bit more info about APs, its firmware, where are are clicking on finish.
  • 3.  RE: invalid set request
    Posted Sep 11, 2024 07:32 AM
    Don't know if you're still having this problem, but in case anyone else comes across this like I did, this is what I did to fix the error.
    Don't push the changes in your Mobility Conductor. Discard all changes and see if you have any lingering roles or policies (Configuration - Roles & Policies) with the same name as the SSID you're trying to create. I had to reboot my mobility conductor to clear those policies out (I was trying to "recreate" a SSID that was in there in the past).
    After the reboot, I was able to create the new captive portal from the wizard without any errors.
    Hope this helps!
