Investigate 'roaming' issues in Instant VC
  • 1.  Investigate 'roaming' issues in Instant VC
    Posted Nov 18, 2016 08:31 AM
    Hi there, a customer of us is reporting roaming issues for e.g. a Samsung Tablet and a Macbook.
    They say while walking though the office, the connection dissapears and reconnects later on if they Disable > Enable WiFi on the devices.
    This is not good. I want to understand how to investigate roaming issues fromout the Instant VC using Airwave. We don't have remote access via SSH to the instant VC.
    Which command should I run fromout Airwave to investigate what a problem can be / and to adjust settings?
    ARM Client Match is enabled. CM calcutlating interval is set to 20 seconds and Neighbour matching is set to 60%
  • 2.  RE: Investigate 'roaming' issues in Instant VC
    Posted Nov 18, 2016 08:51 AM
    What is the minimum and maximum transmit power under RF> ARM?
  • 3.  RE: Investigate 'roaming' issues in Instant VC
    Posted Nov 18, 2016 08:57 AM
    I see minimum = 9 and maximum = 18
  • 4.  RE: Investigate 'roaming' issues in Instant VC
    Posted Nov 18, 2016 09:00 AM
    Okay.  What is the RF utilization on the band that the client is running on?
