IOS 7 not working well on iPad and iPhone
  • 1.  IOS 7 not working well on iPad and iPhone
    Posted Mar 01, 2014 11:53 PM
    Hello All,
    I am having a customer using AP225 as a remote AP bridge mode, client in use is iPad and iPhone on IOS 7. When the client goes idling after 30 minutes or so the client cannot connect back to the wireless. Although we can see from debug the 802.1x has been sent to the controller and to the Radius (Steelbelt Radius) but we couldn;t see the success on the radius on the debug. Only after we switch off and on the WLAN on the client then it is able to get authenticated sucessfully.
    The way out of this is to remove all the WLAN profile on the iPad and iPhone then even after the client when idling for any amount of time it is able to get connected back to the WLAN. Anyone is having the same issue and is there any other solution to this problem.
    AirOS in use is 6.3.1.2, controller is 7210, AP is 225 in bridge mode.
    #AP225
    #7210
  • 2.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 02, 2014 12:09 AM
    FYI, tested on Samsung Note 8.0 and 10 is working fine even with multiple WLAN profiles.
  • 3.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 02, 2014 02:21 PM
    • Did u change anything in the logon role?
    • What are your AAA timers?
    • Can u please printout the all your Access roles/AAA profiles/VAP configuration your are using.
  • 4.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 08, 2014 02:07 AM
    Hello kdisc98
    Nothing change on the logon role.
    (Controller) #show aaa timers
    Global User idle timeout = 300 seconds Auth Server dead time = 10 minutes Logon user lifetime = 5 minutes User Interim stats frequency = 600 seconds
    user-role denyall
    user-role logon
     captive-portal "default"
     access-list session ra-guard
     access-list session logon-control
     access-list session captiveportal
     access-list session vpnlogon
     access-list session v6-logon-control
     access-list session captiveportal6
    user-role SH-Shop-Authenticated
     access-list session allowall
    wlan virtual-ap "St_Shop_Corp"
       aaa-profile "St_Shop-aaa_prof"
       ssid-profile "St_Shop_Corp-ssid-prof"
       vlan 230
       forward-mode bridge
       allowed-band a
       no broadcast-filter arp
       auth-failure-blacklist-time 5
       blacklist-time 5
       no mobile-ip
       vlan-mobility
    aaa profile "St_Shop-aaa_prof"
       initial-role "denyall"
       authentication-mac "St_Shop_MAC-prof"
       mac-default-role "SH-Shop-Authenticated"
       mac-server-group "St_Shop_rad-server"
       authentication-dot1x "St-PS-PSK-Profile"
       dot1x-default-role "logon"
    wlan ssid-profile "St_Shop_Corp-ssid-prof"
       essid St@PS
       opmode wpa2-psk-aes
       a-tx-rates 36 48 54
       max-clients 128
       no disable-probe-retry
       wpa-passphrase c5f059c561181e2f317411b407609ccb8955b1048bc374ff99ce9ecf445ef35793c74b62c89f3b03
    Hope this is enough.
  • 5.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 08, 2014 04:07 AM
    Please,Change the denyall to logon role.. And let me know if it working as needed.
  • 6.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 08, 2014 04:51 AM
    Let me change it and then revert. Thanks
  • 7.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 09, 2014 10:22 AM
    what exactly is this setup? i see mac auth roles, i see captive portal profiles, i see you mention dot1x, it feels like a lot of unneeded extras are configured here.
    could you explain what exactly the required authentication setup should be?
    @kdisc98 on what do you base the initial role should be changed? it works on android like this, why would changing this role help with IOS?
  • 8.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 09, 2014 10:33 PM
    Hello Boneyard,
    Yes, some unnecessary, we are using 802.1x not MAC auth here.
  • 9.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 09, 2014 10:45 PM
    Normal Guy,
    It is not clear what you are presenting us with here.  You should show us the role that a user gets when he/she is authenticated and type "show rights <role>" so that we can see the ACL involved.
    If you are bridging user traffic, why would the 802.1x default role be logon?  That makes no sense.  You cannot do captive portal on a bridged SSID!  If the user gets a different role than the 802.1x default role, please show us the ACLS from THAT role..
    Why do you have the a-tx-rates manipulated, but not the corresponding basic rates or the beacon rates?
    a-tx-rates 36 48 54
    Why is broadcast filter ARP off?
    Each one of these presents issues by itself!
  • 10.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 10, 2014 12:07 AM
    Hi Joseph,
    Thanks as we have gotten this controller from another vendor and there is a need for clean up. Let me do some clean up and then advise. Mainly device getting connected is via iPad doing 802.1x using Stealbelt radius with MAC address as the username and password. Since this is bridge mode no CP is enabled and we cannot see the role of the client via show user.
  • 11.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 10, 2014 12:33 AM
    Not true.  Bridged clients show up in the user table with a forwarding mode of bridge.
    It would seem that you need to first clean up the customer configuration and then attempt to replicate the IOS7 issue.  THEN if you still can replicate it, post questions about things that do not seem right.  It would take more time to post parts of a problem configuration and have the forum guess what the probem could be...
  • 12.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 10, 2014 12:39 AM
    Hello Joseph
    a-tx-rates 36 48 54
    We are making sure that the connect at high rate and not the low rates but this will set back to usual as it is not the issue.
    Roaming from A radio when this is on it is disconnect and doesn't reconnect.
  • 13.  RE: IOS 7 not working well on iPad and iPhone
    Posted Mar 10, 2014 12:46 AM
    You will only get the actual benefit if you change the basic rates, as well http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Dramatic-utilization-reduction-in-2-4GHz-spectrum/m-p/92186/highlight/true#M2947
    Broadcast Filter ARP has no effect in bridge mode, but it should not be turned off.
