iOS Captive Portal Issues
This thread has been viewed 56 times
  • 1.  iOS Captive Portal Issues
    Posted Feb 28, 2024 05:23 AM
    We are running a Physical Gateway Cluster to Aruba Central and Aruba Clearpass.  We suddenly are having issues with iOS and Apple devices not being able to load the captive portal page, both via CPN and browsing directly to any site.  The pop up just says "error loading page".  This is impacting all apple devices.  All other clients (Windows and Android) work fine.  We have tried the following
    • insured that we are using a publicly signed SSL certificate.
    • verified that DNS and DHCP are functioning as expected
    • created a bridged captive portal SSID directly to Central, eliminating the controllers
    • Tried allowing everything in the login role
  • 2.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 10:12 AM
    Some screenshots would probably be helpful here.
    Basically the same issue as described in https://community.arubanetworks.com/discussion/internal-captive-portal-does-not-load-on-apple-captive-network?
    Carson Hulcher, ACEX#110
  • 3.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 10:34 AM
    While the issue is similar to the other post, it is not quite the same.  We cannot browse to another page and trigger the captive portal, so no apple devices can get on to our guest network at all.  I can type the url in for the Captive Portal page and it will load, but the credentials are rejected due to way the Clearpass rules are set up.
    Everything used to work fine when we had just the controllers and Clearpass.  It wasn't until we set up Aruba Central and had our controllers tunneled into Central as Gateways that the issue started.
  • 4.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 10:21 AM
    Did you set the captive portal certificate usage at the AP or at the gateway?
  • 5.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 10:41 AM
    We set the certificate in three places:
    • Aruba Central > Devices > Gateways  > Certificates
    • Aruba Central > Devices > Access Points > Security > Certificate Usage > Captive Portal
    • Both Clearpass Servers  > Certificate Store > Server Certificates > HTTPS(RSA) Server Certificate
    We also removed all the certificates and created new ones just in case something got corrupted.
  • 6.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:02 AM
    No reason to have the certificate set at the gateway, the AP is doing the redirect and login.  Set the captive portal certificate for the gateways back to default or aruba_default.
    Just to validate, the certificate used on the AP is not the same certificate used on ClearPass, right?
  • 7.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:19 AM
    I reset the certificates back to the default on the server
    This is what the AP Certs look like:
    We do have the same certificate on both the APs and Clearpass.  It is a wildcard certificate.
  • 8.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:09 AM
    If it helps, here are the rights for the login role:
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'WCR2-Guest_CP'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Number of users referencing it = 67
     Periodic reauthentication: Disabled
     DPI Classification: Enabled
     Youtube education: Disabled
     Web Content Classification: Enabled
     IP-Classification Enforcement: Enabled
     ACL Number = 127/0
     Openflow: Enabled
     Max Sessions = 65535
     Check CP Profile for Accounting = TRUE
    Application Exception List
    Name  Type
    Application BW-Contract List
    Name  Type  BW Contract  Id  Direction
    access-list List
    Position  Name                      Type     Location
    1         global-sacl               session
    2         apprf-wcr2-guest_cp-sacl  session
    3         wcr2-guest_cp             session
    4         logon-control             session
    5         captiveportal             session
    global-sacl
    Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Denylist  Mirror  DisScan  IPv4/6  Contract  Mark  Description
    wcr2-guest_cp
    1         any     wcr2-guest_cp_captiveportal.wrightcity.k12.mo.us  svc-https               permit                           Low                                           4
    2         any     wcr2-guest_cp_captiveportal.wrightcity.k12.mo.us  svc-http                permit                           Low                                           4
    3         any     any                                               svc-dhcp                permit                           Low                                           4
    4         any     any                                               svc-dns                 permit                           Low                                           4
    5         any     any                                               svc-icmp                permit                           Low                                           4
    logon-control
    1         user    any                      udp 68                 deny                             Low                                           4
    2         any     any                      svc-icmp               permit                           Low                                           4
    3         any     any                      svc-dns                permit                           Low                                           4
    4         any     any                      svc-dhcp               permit                           Low                                           4
    5         any     any                      svc-natt               permit                           Low                                           4
    6         any     169.254.0.0 255.255.0.0  any                    deny                             Low                                           4
    7         any     240.0.0.0 240.0.0.0      any                    deny                             Low                                           4
    captiveportal
    1         user    controller   svc-https                     dst-nat 8081                           Low                                           4
    2         user    any          svc-http                      dst-nat 8080                           Low                                           4
    3         user    any          svc-https                     dst-nat 8081                           Low                                           4
    4         user    any          svc-http-proxy1               dst-nat 8088                           Low                                           4
    5         user    any          svc-http-proxy2               dst-nat 8088                           Low                                           4
    6         user    any          svc-http-proxy3               dst-nat 8088                           Low                                           4
    Expired Policies (due to time constraints) = 0
  • 9.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:17 AM
    There's the problem, you're attempting this from the Gateway.
    AOS 10 you need to configure your captive portal network entirely from the AP side, using the WLAN wizard.
    The AP does the authentication and redirect, not the Gateway.
  • 10.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:23 AM
    Can you be more specific on where my problem is and what I need to fix?  This was set up with the wizard.
  • 11.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:28 AM
    Did you modify the user role on the gateway side?
  • 12.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:37 AM
    The role has not been modified on the Gateway side.
  • 13.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 11:51 AM
    As an example, here's the captive portal role on my gateway:
    (GW-Guest-01) #show rights cp-aos10-guest
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'cp-aos10-guest'
     Number of users referencing it = 0
     ACL Number = 127/0
     Openflow: Enabled
     Global Role Tag: 800
    Name  Type
    access-list List
    2         apprf-cp-aos10-guest-sacl  session
    3         cp-aos10-guest             session
    global-sacl
    cp-aos10-guest
    1         any     cp-aos10-guest  svc-https               permit                           Low                                           4
    2         any     cp-aos10-guest  svc-http                permit                           Low                                           4
    If we look at yours there are additional ACLs applied to the role: logon-control and captiveportal, so the user role has definitely been modified through the gateway configuration.
    With AOS 10 and looking at a user role on the gateway, when modifying a user role for a tunneled or mixed WLAN through the WLAN wizard, all of the ACL edits are contained within the ACL entry that is named the same as the user role.
    access-list List
    3         wcr2-guest_cp             session        <- talking about this ACL
    access-list List
    3         cp-aos10-guest             session  <- or this one from my example
    Notice the difference between the expected setup and what you've got?
  • 14.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 12:29 PM
    Ok, so we got that changed, but the behavior has not changed.  Here is the current  rights role
    show rights wcr2-Guest_Cp
    Valid = 'Yes'
    CleanedUp = 'No'
     Number of users referencing it = 59
     ACL Number = 127/0
     Openflow: Enabled
    Name  Type
    access-list List
    global-sacl
    wcr2-guest_cp
  • 15.  RE: iOS Captive Portal Issues
    Posted Feb 28, 2024 12:41 PM
    Since there was a modification to the user role, there's no guarantee at this point that something else isn't wrong or problematic in the configuration.
    Two recommendations at this point:
    • Delete the guest WLAN that you've configured, making sure to remove the captive portal profile from the AP configuration and anything extraneous that shows up on the gateway, then create the guest WLAN again from scratch.
    • Contact TAC and see if they can find the problem.
