iOS Device Reconnect Post Provisioning
  • 1.  iOS Device Reconnect Post Provisioning
    Posted Jan 21, 2013 05:22 PM
    Having some issues where some apple ios devices are getting an error message (attached) on the post provisioning page when attempting auto reconnect.  It doesn't seem to be related to any particular phone model or ios version.  Same results when using the manual reconnect.  Note:  I blocked out some areas of the screenshot.  Thoughts?
  • 2.  RE: iOS Device Reconnect Post Provisioning
    Posted Jan 21, 2013 08:16 PM
    Check the application log - you might find some more clues as to why it is failing in there.
  • 3.  RE: iOS Device Reconnect Post Provisioning
    Posted Jan 22, 2013 09:25 AM
    no failures in the application log or access tracker.  The device is successfully connecting however the error message on the page says it's failing
  • 4.  RE: iOS Device Reconnect Post Provisioning
    Posted Jan 24, 2013 08:56 AM
    found this in the app log when debug was on:
    Failed to issue the RADIUS disconnect request for auto-connect
    Script:    /guest/mdps_profile.php
    Function:  NwaMdpsProfileDoDisconnect
    Details:   (
      'result' => (
        'error' => 1,
        'message' => 'Could not retrieve profile values (1)',
  • 5.  RE: iOS Device Reconnect Post Provisioning
    Posted Jan 24, 2013 01:05 PM
    2 things
    1. First make sure you have COA and Aruba selected as the vendor in CPPM
    2. Make sure you check mark the Add switch IP address in the redirection URL in the captive portal settings in the controller.
