iOS Distribution Certificate Setup
  • 1.  iOS Distribution Certificate Setup
    Posted Feb 28, 2014 12:40 PM
    Hi all
    I am trying to configure Clearpass 6.3 and the customer would like to use the MDM feature, as part of this they'd liked to push apps from their itunes business account, these apps aren't available through a standard itunes account.
    Am I right in assuming that this would be done through the iOS Enterprise app link in App Management under the Onboard initial setup section?  If so I need to add an iOS Provisioning Profile and in order to do this I need an iOS Distribution Certificate.  I've created the CSR however but can't seem to find where to submit it...  The link on the page advising where to submit it, (https://developer.apple.com/membercenter/) doesn't make it any clearer.
    To cut to the chase has anyone else had experience of this and can point me in the right direction.
    Many thanks
    Mark
  • 2.  RE: iOS Distribution Certificate Setup
    Posted Mar 01, 2014 01:19 AM
    You need to work with your local Clearpass Specialist.
    It all depends on if the customer has their app published to the app store or b2b store
    To get an IOS dis cert you will need to setup a devloper account. Apple has two different paid versions
    1. Standard - Max 100 devices
    1. Enterprise- unlimited but you will need to have a Dun and Bradstreet listing
  • 3.  RE: iOS Distribution Certificate Setup
    Posted Mar 03, 2014 09:30 AM
    Thanks for your quick reply Troy.
    I'm not sure what type of account the customer has however I will find out and pass on your information.
    I also found this link on youtube which includes the steps required to submit the CSR.
    http://www.youtube.com/watch?v=oi6eqa8vtG8
    Hopefully this will be useful for others too.
    Many thanks
    Mark
