iOS using Chromecast with IAP-225 for Netflix
  • 1.  iOS using Chromecast with IAP-225 for Netflix
    Posted Aug 27, 2017 12:00 AM
    This has stumped me for a while, and I'm not exactly sure if it's related to the Aruba cluster, or if it's an issue with Netflix/Google/Apple/etc.
    I got a company phone not to long ago, which was an iphone, I was previsouly and android person (still am) and all of the settings I normally enable for customers to use chromecast are enabled, and verified working, since my androids had no problem streaming. But for the life of me, I can't get my iPhone to stream anything, or even detect the chromecast. The google Home app, sees the chromecast, but it doesnt pop up in any apps to use it.
    I am running 6.5.2.0 on a two AP cluster of IAP225's, All Airgroup services enabled, using a 2.4GHz only SSID for the chromecast, client match is off, DMO, MTO and broadcast filtering are disabled.
  • 2.  RE: iOS using Chromecast with IAP-225 for Netflix
    Posted Aug 27, 2017 02:17 AM
  • 3.  RE: iOS using Chromecast with IAP-225 for Netflix
    Posted Aug 28, 2017 10:00 PM
    Aruba# show airgroup blocked-queries
    AirGroup dropped Query IDs
    Service ID #query-hits
    _sleep-proxy._udp 2317
    _fb._tcp 214
    urn:smartspeaker-audio:service:SpeakerGroup:1 63
    _samsungmsf._tcp 12
    4d690594._sub._apple-mobdev2._tcp 7
    uuid:93a437b3-1f9d-45cd-8062-b49593567fdb 2
    uuid:b54e570b-0066-cc15-2a67-4fb7d7f1ded4 2
    uuid:59c79254-64c0-17a6-2651-3b65f28de8ac 2
    uuid:10225311-3009-2000-0000-7ced8dc373ff 2
    uuid:fa92731b-bedb-459a-88bf-fa90a5698a7f 3
    Num dropped Query IDs:10
    Should I just create a new service for those and hope for the best?
  • 4.  RE: iOS using Chromecast with IAP-225 for Netflix
    Posted Oct 17, 2017 08:46 PM
    I still would like assistance with this. I have not found a workaround.
  • 5.  RE: iOS using Chromecast with IAP-225 for Netflix
    Posted Jan 02, 2018 04:47 AM
    Same problem occurs with the 103. I solved the problem for my network by changing the broadcast filtering setting within the SSID WLAN settings. (after i did all the things mentioned in this thread)
    Go to your virtual controller and edit your SSID, click on "advanced setting" -> WLAN settings tab -> change the setting for "broadcast filtering" to "disabled" (instead ARP)
    Good luck!
  • 6.  RE: iOS using Chromecast with IAP-225 for Netflix
