IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
  • 1.  IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
    Posted Nov 27, 2017 11:38 PM
    I have been following the Video Tutorials provided by Herman and i have been able to get my clearpass where it will authenticate both PEAP and TLS Windows AD Clients without any issue.
    I have moved onto the onboarding and again followed the videos and have been able to successfully onboard a windows client.
    When i try to authenticate an IOS or OSX device i get an issue about certificates.
    I am using a CP Hosted Root CA.
    From what i can see from the profile, the certificates are passed and enabled for trust they just don't connect.
    In the logs i get an error about 'TLS_accept:error in SSLv3 read client key exchange A'
    I am not sure what is different, when i search on the error a lot of sites indicate that it is issue with the client not trusting the Root CA certificate but from what i can see the certificate is installed as a trusted root ca.
    Any advice on how to troubleshoot this.
    Attachment(s)
    zip
    WindowsOnboard.zip   7 KB 1 version
    zip
    IOSOnboard.zip   7 KB 1 version
  • 2.  RE: IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
    Posted Nov 28, 2017 12:04 AM
    Is your EAP server certificate SHA-2?
  • 3.  RE: IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
    Posted Nov 28, 2017 12:14 AM
    the CA Root Server is SHA512 and the Client Certificates generated from it are SHA512 as well with 2048bit key.
    The Radius Client Certificate is SHA1 with 2048bit key.
    i have attached example cert
    Attachment(s)
    zip
    byot.test.zip   1 KB 1 version
  • 4.  RE: IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
    Posted Nov 28, 2017 12:18 AM
    Your EAP server certificate needs to be SHA-2 or higher.
  • 5.  RE: IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
    Posted Nov 28, 2017 06:07 AM
    Hi Seic,
    I think you're doing lab testing with ClearPass Onboard feature, so using SHA-512 is not really an issue. If you plan to implement Onboard in a production environment, using SHA-512 for each client cert may cause serious performance issue. I would go for SHA-256 instead.
    Thank you,
  • 6.  RE: IOS/OSX Onboard Error, failed in SSLv3 read client certificate A
    Posted Jan 14, 2018 10:19 AM
    Hi, I have the same question,Can you tell me the solution?
