Wired Intelligent Edge
IP Accounting for count traffic for end to end communication on Aruba CX 6300
  • 1.  IP Accounting for count traffic for end to end communication on Aruba CX 6300
    Posted Jul 01, 2022 04:22 AM
    Hello Guys,
    I want to migrate from L3 Switch to Aruba CX 6300. There is IP Accounting command in vlan interface.
    The implementation as follows:
    interface Vlan6
    description Lantai 2
    ip address 10.145.54.1 255.255.255.128
    ip access-group Bill_Payment in
    ip helper-address 10.145.60.201
    ip helper-address 10.194.22.197
    ip accounting output-packets
    based on docummentation :
    Cisco IP accounting support provides basic IP accounting functions. By enabling IP accounting, users can see the number of bytes and packets switched through the software on a source and destination IP address basis. Only transit IP traffic is measured and only on an outbound basis; traffic generated by the software or terminating in the software is not included in the accounting statistics. To maintain accurate accounting totals, the software maintains two accounting databases: an active and a checkpointed database.
    my question is, is Aruba CX 6300 can support this feature or maybe there is work around for this feature?
    Thanks and Regards,
    Luthfi
  • 2.  RE: IP Accounting for count traffic for end to end communication on Aruba CX 6300
    Posted Jul 01, 2022 04:23 AM
    And the show command result as follows:
    show ip accounting
       Source           Destination              Packets               Bytes
     172.16.19.40    192.168.67.20                  7                 306
     172.16.13.55    192.168.67.20                  67                2749
     172.16.2.50     192.168.33.51                  17                1111
     172.16.2.50     172.31.2.1                     5                 319
     172.16.2.50     172.31.1.2                     463               30991
     172.16.19.40    172.16.2.1                      4                 262
     172.16.19.40    172.16.1.2                      28                2552
     172.16.20.2     172.16.6.100                    39                2184
     172.16.13.55    172.16.1.2                      35                3020
     172.16.19.40    192.168.33.51                  1986               95091
     172.16.2.50     192.168.67.20                   233               14908
     172.16.13.28    192.168.67.53                   390               24817
     172.16.13.55    192.168.33.51                214669             9806659
     172.16.13.111   172.16.6.23                  27739             1126607
     172.16.13.44    192.168.33.51                 35412             1523980
     192.168.7.21    172.163.1.2                      11                 824
     172.16.13.28    192.168.33.2                     21                1762
     172.16.2.166    192.168.7.130                   797              141054
     172.16.3.11     192.168.67.53                     4                 246
     192.168.7.21    192.168.33.51                 15696              695635
     192.168.7.24    192.168.67.20                    21                 916
     172.16.13.111   172.16.10.1                     16                1137
     accounting threshold exceeded for 7 packets and 433 bytes
  • 3.  RE: IP Accounting for count traffic for end to end communication on Aruba CX 6300
    Posted Jul 04, 2022 12:43 AM
    AOS-CX devices does not support this feature. We do have only Client IP Tracker feature, that can track the IPs of end devices. For more information refer -
    https://www.arubanetworks.com/techdocs/AOS-CX/10.09/HTML/cli_6000-6100/Content/Chp_IPClientTrack/IPClientTrack_cmds/cli-tra-ip.htm
    Shobana
    Aruba
  • 4.  RE: IP Accounting for count traffic for end to end communication on Aruba CX 6300
    Posted Aug 05, 2022 04:54 AM
    Hi Luthfi,
    Workaround for now is using sFlow and a sFlow Collector to see L3/L4 statistics per port. To have your request in future release of AOS-CX you could enter a feature request in https://innovate.arubanetworks.com/
