Ip address issue
  • 1.  Ip address issue
    Posted Feb 21, 2021 06:49 PM
    Why i have to untagged management vlan on switch in order to obtain ip address for iap
    And also why in show cdp neighbors details command it is not showing  dhcp switch IP WHY 169 series ip?
    Shivam Ojha
  • 2.  RE: Ip address issue
    Posted Feb 21, 2021 11:49 PM
    A common practice with IAPs is the following
    1) Configure Your switch port where the IAP will connect as trunk (Native untagged vlan is your mgmt vlan, tagged vlans are your users vlans)
    2) Your IAP will connect and get an IP address from the management vlan - You need to have a DHCP server on this management vlan or you need to manually configure a static IP for the IAP. By default, the IAP is configured not to tag the MGMT traffic so it is expecting to connect to a port where it is either access port with mgmt vlan or trunk port with untagged mgmt vlan.
    3) Configure your wireless network(s) to use a static vlan(s) matching your environment.
    Note: You can deploy it in multiple other ways (for example having tagged mgmt vlan..etc.)
    Ayman Mukaddam
  • 3.  RE: Ip address issue
    Posted Feb 22, 2021 03:14 AM
    Having untagged vlan for management is, like Ayman mentioned how you should do it. There is no real why, that is just how it works. There is a possibility to have a tagged management VLAN, but please stay away from that. Also in the IAP, you can configure a management VLAN, but leave that empty to have the management traffic untagged.
    After you have done that, if you still see that cdp neighbors 169.254.x.x IP for the switch, post the output of the command and exactly on what type of device your see that output. If you didn't have an untagged management VLAN assigned on the switch port that connects to the IP, and the output is on the switch reporting the IP of the IAP, that can well be the reason and it should be better after fixing your configuration.
  • 4.  RE: Ip address issue
    Posted Feb 24, 2021 08:24 AM
    Hi Herman,
    could you put some more light on your statement "There is a possibility to have a tagged management VLAN, but please stay away from that."
    Why it's not recommended to use tagged for the management VLAN ?
    I now it's nothing directly related to this issue - but would be interesting to get to know
    Thanx and Groetjes
    Jochem
    Jochem Knoben
  • 5.  RE: Ip address issue
    Posted Feb 24, 2021 08:44 AM
    First is that the product has been designed for ease of deployment, and with having the management VLAN untagged there is no pre-required configuration to add APs, configure, add more in a cluster, etc. With the management VLAN tagged, you need to pre-configure each of your APs.
    The question back would be, why would you want to have the management network tagged? You can have one untagged VLAN on most switches, and from the architecture design of Instant, it makes sense to have that for management.
    Secondly, initially having a tagged management VLAN was not even possible, and the feature was added for a customer that could for one reason or the other not have the management VLAN untagged (or it was hard, or the old solution that was replaced was setup like that). By far most deployments are with the management VLAN untagged, according to the best-practice. I see relatively many questions and issues on the Airheads forum around deployments with tagged management VLAN. By sticking to the basics, you avoid possible issues and keep things as simple as possible. That also is where best-practices are for... replicate a proven concept, which makes deployments but also troubleshooting easier. I prefer to keep things as simple as possible.
