Helo, I lost address IP of our aruba, how then I to find it ?
Thanks a lot.
What do you mean by that ?
You can look at your IP address setup by running the following command :
show ip interface brief
show controllerip
Because you don't know the IP, you'll need to run Victor's commands while connected to the console port on the controller.
Thank you very much, i build the cable and i found the ip master.
Best regards
