Wired Intelligent Edge
ip forward-broadcast ACL
This thread has been viewed 16 times
  • 1.  ip forward-broadcast ACL
    Posted Jul 13, 2016 09:28 AM
    I have a HPE 5510 switch which is comware 7 based.
    I need “ip forward-broadcast”. So this isn’t hard to configure but in comware 5 it was possible to add an ACL to the “ip forward-broadcast”.
    Acl 3001
    rule 10 permit udp source 192.168.200.0 0.0.0.255 destination 10.0.0.255 0 destination-port eq 9
    Comware 5: ip forward-broadcast acl 3001
    Comware 7: ip forward-broadcast
    So to have less broadcast forwarded how to add a acl to the “ip forward-broadcast”
  • 2.  RE: ip forward-broadcast ACL
    Posted Sep 26, 2016 06:38 AM
    Had the exact same question this morning:
    You can just apply an acl to the interface with 'packet-filter 3001 outbound' (or inbound, depending of your network config).
    Your ACL may be:
    Acl 3001
      rule 15 deny ip destination 10.0.0.255 0
    rule 20 permit ip
    Hope this can help someone avoiding loosing time…
  • 3.  RE: ip forward-broadcast ACL
    Posted Aug 01, 2017 11:16 AM
    I am having the same problem. about packet-filter solution, doesn't it block all unicast and multicast traffic too along with broadcast?
  • 4.  RE: ip forward-broadcast ACL
    Posted Mar 14, 2018 11:07 AM
    The rules I gave should let directed-broadcast work if coming from 192.168.200.0/24 and to udp port 9 (wake-on-lan), blocking all other directed-broadcast from outside of the LAN (but not multicast, which is 224/4 if my memory doesn't fail here)
    This is true with "packet-filter filter route" on the interface you apply acl on, it may block internal broadcast on LAN if "packet-filter filter all" (don't remember which one is the default one…)
  • 5.  RE: ip forward-broadcast ACL
    Posted Sep 04, 2018 12:17 PM
    try this solution based on UDP-Helper, this should work for WOL for Comware 7:
    Configuration files #
    udp-helper enable
    udp-helper port 9 # maybe port 7 too and sometimes 12287 as well
    vlan 1 # Deployment-Server
    vlan 2 # Client Lan
    interface Vlan-interface1
    ip address 10.110.1.1 255.255.0.0
    udp-helper server 10.2.1.255
    interface Vlan-interface2
    ip address 10.2.1.2 255.255.0.0
    ---snipp---
    Ralf
