Comware
ip forward-broadcast on HPE 5710 IRF-Stacks
  • 1.  ip forward-broadcast on HPE 5710 IRF-Stacks
    Posted Sep 12, 2022 03:56 AM
    Hello community,
    i need your help.
    In a critical environment i need to replace old 5820-switches (Comware 5 - latest) with newer ones (5710 - v7.10 2612 P10).
    Due to special software requierements a broadcast of a user-terminal (changing) needs to be transportet to every other user terminal (on purpose). Also to a second customer location (connected via IP-Sec-Tunnel and ip-routing between the switch-stacks).
    To allow this on comware 5 i hat to activate ip forward-broadcast on a "global" config-scale and also in every "ip vlan-interface".
    Now on Comware 7.1 there ist no "global ip forward-broadcast" switch on the cli, only in "ip interface vlan" context.
    Am i missing here something, or is this global switch not needed.
    btw. this is NO dhcp-helper!!! It is a very special Software, that depends on realtime data distribution via broadcast. (Unicast beeing to slow)
    Please forward even the smallest idea.
    THX
    FHegnauer
    prefers to not experiment with live customer equipment...
