Comware
  • 1.  ip-helper - HP 2920 stack
    Posted Apr 28, 2014 09:44 AM
    I am trying to set up a network with users on one VLAN and Servers on the other just for practice. I can't seem to find the ip-helper setting, is this a command line option? If so can you provide me with the specific, I have tried a couple but they they do not seem to work on my switch. It is a HP 2920
    Thank you
    #helper
    #ip
    #VLAN
    #DHCP-relay
    #relay
    #switch
    #ip-helper
    #server
    #vSphere
    #DHCP
    #Networking
    #routing
    #telnet
  • 2.  RE: ip-helper - HP 2920 stack
    Posted Apr 29, 2014 07:13 AM
    After 401 views and still no one able to help I have found the answer for myself,
    for anyone looking for the same answer this is the solution.
    After telnetting to the switch and logging in rather than typing 'menu' type 'config' and enter the below commands (without < >)
    vlan xx
    name "xxx"
    ip address <VLAN IP> <subnet mask>
    ip helper-address <ip address of dhcp server>
    tagged xx
    write mem
    exit
