IP Mobility - Mobile IP - VLAN Mobility
  • 1.  IP Mobility - Mobile IP - VLAN Mobility
    Posted Aug 10, 2012 07:10 PM
    What is the difference between enabling IP Mobility under Advanced Services which issues the “router mobile” command, compared to enabling Mobile IP within a Virtual AP profile which issues:
    wlan virtual-ap "Virtual AP name"
      mobile-ip
    In our environment we do not need layer 3 roaming, and all AP’s that support a building all terminate to the same controller. We currently do NOT have Mobile IP enabled but we DO have Mobile IP and VLAN Mobility enabled. I don’t think we want either one of these enabled, and am wondering if having these enabled might be a bad idea. Currently if I am at site A and I shut down my laptop and go to site B 10 miles away who has a Virtual AP profile that specifies a different VLAN, I will actually still have the IP from site A even though we do not have Mobile IP enabled, and this is a feature we do not require.
    Thanks for your advice!
  • 2.  RE: IP Mobility - Mobile IP - VLAN Mobility
    Posted Aug 11, 2012 11:59 AM
      mobile-ip
    mobile-ip under the virtual AP allows clients to roam from one controller to the other on the same VLAN.  I think that is the setting you want.
    ip mobility allows a device to roam from one controller to the other when the same user VLANs are not available on both controllers.
