ip NAT Pool command rejected
  • 1.  ip NAT Pool command rejected
    Posted May 16, 2019 05:23 PM
    Hi all.
    I'm in to process to provisioning a local controller 7010-us and this command won't take."ip NAT Pool command rejected"
    I get:
    (WLC) (config)# ip NAT pool
    % Invalid input detected at '^' marker.
    I.m running Aruba OS 6.5.4.6. in a lab environment
    Also I don't see the "IP NAT" Tab under the
    Network > IP > IP Interface
  • 2.  RE: ip NAT Pool command rejected
    Posted Oct 07, 2019 11:12 AM
    same issue here on a 7008 6.5.4.8.
    do you have any output using: show ip nat pool
  • 3.  RE: ip NAT Pool command rejected
    MVP EXPERT
    Posted Oct 07, 2019 11:18 AM
    Do you have a PEFNG license installed? This command requires the PEFNG license.
