Comware
  • 1.  IP Phone not working on HP 1920 switch
    Posted Oct 10, 2017 02:41 AM
    Hello
    We have HP 1920 (JG924A) switch at remote location. Having only 1 VLAN (Default VLAN - 1). All ports are access ports. Switch HP 1920 is connected with another uplink switch HP E-3800 that too has only 1 VLAN (Default VLAN-1) all ports are untagged in VLAN 1. That switch HP e-3800 is uplink with Cisco router.
    There are PC / workstations , printers, IP Phones. All of them working fine on HP-E3800.
    But IP Phones are not working on HP-1920. Able to ping the IP phone but service is not working. When shifting IP Phone to HP E-3800 it works fine.
    Help needed.
    #IPPhone
    #VoIP
    #Switching
  • 2.  RE: IP Phone not working on HP 1920 switch
    Posted Oct 11, 2017 02:55 AM
    Can you share port(s) configurations used at both ends (HPE OfficeConnect 1920 and HPE 3800) to form the uplink?
  • 3.  RE: IP Phone not working on HP 1920 switch
    Posted Oct 12, 2017 01:41 AM
    Switch HPE-3800
    Running configuration:
    ; J9585A Configuration Editor; Created on release #KA.15.03.3015
    ; Ver #01:00:01
    hostname "HP-E3800"
    module 1 type J9585x
    interface 25
    name "Uplink_to_HP-1920"
    exit
    interface 26
    name "UPLINK_TO_ROUTER"
    exit
    ip default-gateway x.x.x.x
    vlan 1
    name "DEFAULT_VLAN"
    untagged 1-26
    ip address x.x.x.x y.y.y.y
    exit
    telnet-server listen data
    web-management listen data
    ip ssh listen data
    snmp-server community "abc123" operator
    snmp-server listen data
    spanning-tree
    oobm
    disable
    no ip address
    exit
    tftp server listen data
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    password manager
    password operator
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Switch HP-1920
    version 5.20.99, Release 1108
    sysname HP1920
    domain default enable system
    ipv6
    telnet server enable
    password-recovery enable
    vlan 1
    domain system
    access-limit disable
    state active
    idle-cut disable
    self-service-url disable
    user-group system
    group-attribute allow-guest
    local-user abc123
    password cipher
    authorization-attribute level 3
    service-type ssh telnet terminal
    service-type web
    stp mode rstp
    stp enable
    interface NULL0
    interface Vlan-interface1
    interface GigabitEthernet1/0/1
    port auto-power-down
    stp edged-port enable
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
    interface GigabitEthernet1/0/18
    interface GigabitEthernet1/0/19
    interface GigabitEthernet1/0/20
    interface GigabitEthernet1/0/21
    interface GigabitEthernet1/0/22
    interface GigabitEthernet1/0/23
    interface GigabitEthernet1/0/24
    interface GigabitEthernet1/0/25
    interface GigabitEthernet1/0/26
    interface GigabitEthernet1/0/27
    interface GigabitEthernet1/0/28
    ip route-static 0.0.0.0 0.0.0.0 x.x.x.x
    undo info-center logfile enable
    snmp-agent
    snmp-agent local-engineid ?????
    snmp-agent community read abc123
    snmp-agent sys-info location
    snmp-agent sys-info version v3
    snmp-agent target-host trap address udp-domain x.x.x.x params securityname abc123 v2c
    snmp-agent trap enable default-route
    load xml-configuration
    user-interface aux 0
    authentication-mode scheme
    user-interface vty 0 15
    return
  • 4.  RE: IP Phone not working on HP 1920 switch
    Posted Oct 12, 2017 04:03 AM
    Mmmm...from configuration file the HPE 3800-24G-2SFP+ Switch (J9585A) physical port 25 (it's the first 10GbE port of two, is it right?)  is used as uplink port to the HPE OfficeConnect 1920-24G switch...but on this latter one what port was used as uplink terminating port?
    I ask because HPE OfficeConnect 1920 Switch Series hasn't 10GbE Ports (Ports and Slots are for 1GbE at maximum) so you were forced to use, on both ends, physical ports running at Gigabit Ethernet speed only at best (that's mandatory on the HPE 1920 side). Is that right?
    Question: 10GbE Port 25 and 26 on HPE 3800 can go at 1GbE? in other terms do those ports admit 1GbE/10GbE operation or only 10GbE?
    Have you set both uplink end ports with "Port Type" of type "Trunk" instead of type "Access" permitting VLAN Id 1 to pass? I ask because HPE 3800 Port 25 and HPE 1920 Port x are uplinked so Port Type should be set of type "Trunk" (at least this is the nomenclature and port settings that is recommended on HPE 1920 side, since it is a Comware 5.20 operating system based Switch).
    On HPE 1920 consult User Guide to see how to set the port used as uplink to HPE 3800 of type "Trunk" permitting VLAN Id 1 (VLAN Id 1 is default untagged on all ports so it should be very simple as changing type "Access" to type "Trunk" for the "Port Type" on the port considered for the uplink).
    The HPE 3800 is ProVision operating system based and uses another type of nomenclature to define an uplink port to another switch, generally it is sufficient to configure the VLAN Id 1 to be untagged on the physical port you will use to uplink to another switch (eventually specifiying other tagged VLAN Ids that uplink port would let to flow):
    HPE3800(config)#vlan 1
    HPE3800(config-vlan)#untagged 25
    Then consider to update both Firmware images (R1108 of HPE 1920 is quite old, latest is R1117 or eventually R1116 | KA.15.03.3015 ...what? is that correct? looking here no KA.15.03.3015 was listed so, probably, it is older than the oldest liste which is KA.15.09.0009...by the way latest software release for 16.04 Software Branch of KA Product Line is actually the recent KA.16.04.0008...so, if I were you, I would pay a close attention to my Switch(es) firmware(es) before trying or doing other configurations).
    You should configure your uplink between HPE 3800 and HPE 1920 as described here
  • 5.  RE: IP Phone not working on HP 1920 switch
    Posted Nov 09, 2017 12:50 AM
    Hi parnassus
    Thanks for the detailed response, further to this issue i would like to add same issue observed at another location, same alcatel model ip phone working on HP E3800, but no working on HP 1920.
    This time Cisco router ISR4000 series connected with 1 gbps port of HP E 3800 switch, from HP E 3800 1Gbps port connected with HP 1920 (No 10Gbps port used here).
    On HP 3800 - only VLAN 1 - all ports untagged in VLAN 1
    On HP 1920 - only VLAN 1 - all ports untagged in VLAN 1.
    In the web gui of HP 1920 switch under network tab there is "Voice VLAN" option. What is that ?
