Wired Intelligent Edge
IP Phone PC Port Issues with Aruba network switch
  • 1.  IP Phone PC Port Issues with Aruba network switch
    Posted May 02, 2019 02:06 AM
    We recently upgraded our analog PBX to IP PBX + IP Phones and we are having issues with computers not getting any connection when connected to IP Phone PC Port (passthrough), it is not that the PC not getting any DHCP, it's just 'Link Down'. Its only when we connect to Aruba switches, there is no issue mentioned when connecting to Cisco switch, IP Phone with its voice vlan and the PC Port with its data vlan. We spend some time looking at the Aruba switch configuration just to find out that data/voice vlans,qos,cdp,etc were configured properly.
    Cisco
    Aruba 2530-48-POE+
    Cisco Catalyst 2960
    As we can see from the IP phone GUI
    'Connected to Aruba switch'
    PC Port: Link Down
    Port speed: Auto-Negotiation, Half-Duplex 10Mbps
    'Connected to Cisco switch'
    PC Port: Link Up
    Port speed: Auto-Negotiation, Full-Duplex 100Mbps
    So we tried to manually set the IP Phone PC Port to Full-Duplex 100Mbps, restarted the phone...it works for over a week now and so with other newly installed units.
    Can someone share some knowledge on this?
    Thanks!
  • 2.  RE: IP Phone PC Port Issues with Aruba network switch
    Posted May 02, 2019 04:42 AM
    Have you tried to enable the poe pre standard?
    power-over-ethernet pre-std-detect
  • 3.  RE: IP Phone PC Port Issues with Aruba network switch
    Posted May 02, 2019 10:28 PM
    Yep, we tried enabled poe pre standard too..
  • 4.  RE: IP Phone PC Port Issues with Aruba network switch
    Posted May 02, 2019 05:43 AM
    Hi ,
    Could you share interface config :
    sh run int (interface number )
    sh power-over-ethernet (interface number )
    sh lldp info local-device (interface number )
    Thanks ,
  • 5.  RE: IP Phone PC Port Issues with Aruba network switch
    Posted May 02, 2019 10:26 PM
    Info, both IP Phone + Desktop is connected to int1-2
    -int1, IP Phone PC Port is auto-negotiate (default), PC Port status Link-Down
    -int2, IP Phone PC Port is set manual to Full-Duplex 100Mbps, PC Port status Link-Up
    Here goes the config for both interface ;
    SW010ACCEDSBN# sh run int 1-2
    Running configuration:
    interface 1
    tagged vlan 5
    untagged vlan 4
    exit
    interface 2
    tagged vlan 5
    untagged vlan 4
    exit
    SW010ACCEDSBN# sh power-over-ethernet 1-2
    Status and Configuration Information for port 1
    Power Enable : Yes PoE Port Status : Delivering
    PLC Class/Type : 1/1 Priority Config : low
    DLC Class/Type : 0/- Pre-std Detect : on
    Alloc By Config : usage Configured Type :
    Alloc By Actual : usage PoE Value Config : n/a
    PoE Counter Information
    Over Current Cnt : 0 MPS Absent Cnt : 4
    Power Denied Cnt : 0 Short Cnt : 0
    LLDP Information
    PSE Allocated Power Value : 1.8 W PSE TLV Configured : dot3, MED
    PD Requested Power Value : 0.0 W PSE TLV Sent Type : MED
    MED LLDP Detect : Disabled PD TLV Sent Type : MED
    Power Information
    PSE Voltage : 54.7 V PSE Reserved Power : 1.9 W
    PD Amperage Draw : 34 mA PD Power Draw : 1.9 W
    Status and Configuration Information for port 2
    Over Current Cnt : 0 MPS Absent Cnt : 6
    LLDP Information
    Power Information
    PSE Voltage : 54.9 V PSE Reserved Power : 1.9 W
    SW010ACCEDSBN# sh lldp info local-device 1-2
    LLDP Local Port Information Detail
    Port : 1
    PortType : local
    PortId : 1
    PortDesc : 1
    Pvid : 4
    Poe Plus Information Detail
    Poe Device Type : Type2 PSE
    Power Source : Primary
    Power Priority : Low
    PD Requested Power value = 3.9 Watts
    PSE Allocated Power Value : 1.8 Watts
    Port : 2
    PortType : local
    PortId : 2
    PortDesc : 2
    Pvid : 4
    Thanks!
  • 6.  RE: IP Phone PC Port Issues with Aruba network switch
    Posted May 05, 2019 02:54 AM
    did you added voice command inside voice vlan
  • 7.  RE: IP Phone PC Port Issues with Aruba network switch
    Posted May 05, 2019 03:57 AM
    i did debuging for lldp i am sharing info you can compare with your setup.
    display lldp local-information interface X
    MED information
    Media policy type : voice Signaling
    Unknown Policy : No
    VLAN tagged : Yes
    Media policy VlanID : XXX
    Media policy L2 priority : 6
    Media policy Dscp : 46
    LLDP debug o/p
    I 05/05/19 10:36:12 00077 ports: port X is now off-line
    0453:00:22:44.92 LLDP 0453:00:22:44.92 LLDP mlldpCtrl: 8023at: PoeMgr
    PowerUpdate to LLDP (mtype = LOC_SYS_CHG) on port X
    0453:00:22:44.92 LLDP 0453:00:22:44.92 LLDP mlldpCtrl: 8023at: PowerUpdate
    values PseAloc=18,PdReq=39 (Type=0, Source=1, Priority=3) on port X
    0453:00:22:55.35 LLDP 0453:00:22:55.34 LLDP mlldpCtrl: port : X is up
    I 05/05/19 10:36:23 00076 ports: port X is now on-line
    0453:00:22:55.49 LLDP 0453:00:22:55.49 LLDP mlldpCtrl: 8023at: TX POEP TLV
    PSEAlloc=18 PDReq=39 class=2 on port X
    0453:00:22:55.49 LLDP 0453:00:22:55.49 LLDP mlldpCtrl: lldp refresh pkt sent out
    port : X
    0453:00:22:57.04 LLDP 0453:00:22:57.04 LLDP mlldpCtrl: 8023at: PoeMgr
    0453:00:22:57.04 LLDP 0453:00:22:57.04 LLDP mlldpCtrl: 8023at: PowerUpdate
    values PseAloc=20,PdReq=39 (Type=0, Source=1, Priority=3) on port X
    0453:00:22:57.49 LLDP 0453:00:22:57.49 LLDP mlldpCtrl: 8023at: TX POEP TLV
    PSEAlloc=20 PDReq=39 class=2 on port X
    0453:00:22:57.49 LLDP 0453:00:22:57.49 LLDP mlldpCtrl: lldp refresh pkt sent out
    port : X
