I'm just wondering if someone can explain in words what the "ip routing" command actually does when enabled on a vlan interface.
I don't know when it is needed or not needed. The only time I've ever done anything with this command is to disable on the vlan for a guest network to get a cisco vpn client to work.
Appreciate a more succinct explanation than what's given in the CLI guide.
