IP Scope For IAP105
  • 1.  IP Scope For IAP105
    Posted Nov 25, 2012 06:22 PM
    Is it possible to change the IP scope  on the IAp105's when it is used as the device to assign IPs and Vlan to clients?
  • 2.  RE: IP Scope For IAP105
    Posted Nov 25, 2012 11:33 PM
    If you mean that you want to assign the range that the DHCP of the Virtual controller Assign ip address yes you can  here:dhcp.png
  • 3.  RE: IP Scope For IAP105
    Posted Nov 26, 2012 10:12 PM
    Thanks for the reply.
    Thats what I was looking for.
  • 4.  RE: IP Scope For IAP105
    Posted Nov 26, 2012 10:14 PM
    Im glad that helped you Mario
    Cheers
    Carlos
