Primary (K-12) Education
  • 1.  IP SLA for Aruba?
    Posted Jun 11, 2024 05:18 PM
    Hello all,
    Does Aruba offer anything similar to Cisco's IP SLA tracking to allow for failover to a separate geographic site?
    I attempted to go down the path in this discussion https://community.arubanetworks.com/discussion/default-routes-question#bm3a1e09c9-b5eb-4755-ad76-018953846175
     but found model Aruba 6405 switches do not support this connectivity monitor as that script is not available in the list of scripts on those switches.
    Thank you for any and all help
    Alex
  • 2.  RE: IP SLA for Aruba?
    Posted Dec 08, 2024 08:37 PM
    Hi Alex
    I too have a need for the same feature to redirect as you.  Have you received any direct replies?  Have you found any solutions or ideas to craft a solution?
  • 3.  RE: IP SLA for Aruba?
    Posted Dec 09, 2024 07:01 AM
    The connectivity_monitor script can be found here: https://github.com/aruba/nae-scripts/tree/master/recommended_scripts/connectivity_monitor
    You should upload it to your switch before it will be visible in the list. Have not tried personally, but with the steps in the referred resource, you should be good.
  • 4.  RE: IP SLA for Aruba?
    Posted Dec 09, 2024 08:51 AM
    Herman
    Thanks for sharing and Happy Holidays.
